Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 4motion Bora Wheel Spacers
    if getting 20mm for the rear, maybe get something for the front too. otherwise itll be super obvious that there is spacers in the rear.
    I personally think 5-10mm is the max offset stagger on mk4s for visual reasons
    Apr 2011
    Quote Originally Posted by bundabora View Post
    They look OK. I would much prefer the design of the H & R ones as they don't require the longer bolts and when you take wheels off there are no spacers that fall off and when the bolt on ones are painted with the same colour as the hub, they disappear...
    but each to his own
    I've had a few friends use the ones that require two sets of bolts and they didnt have a good experience with them haha
    I'd rather just have a set of strong longer bolts holding the wheel on and thats it to be honest.
    One of the drift drivers I know uses the same design spacer on his car and it takes an absolute beating with no problem at all, so being confident with that
    I still have no idea what size I should go, I know 20mm will push the rim out to be just under the guard, and I do have KW's in there so I can adjust them if i need too
    2003 Vw Bora.
    V6 4-Motion.
    Black.
    Jan 2011
    Bundaberg
    Yeah sure - I have ET 35 wheels 18x8 and 20mm spacers on the rear (none on the front) and mine look like this.
    Apr 2011
    Awesome
    Any more pics of the rear?
    EDIT: Never mind, found your build thread ^.^
    2003 Vw Bora.
    V6 4-Motion.
    Black.
    Jan 2011
    Bundaberg
    and this better pic?
    Nov 2012
    Melbourne, VIC
    I'd recommend the H&R hubcentric spacers and some longer bolts from ECS, they cost more but are worth it.
    bundabora, is the offset of your wheels et35 before or after spacers? i just purchased some 18x8 wheels and i'm currently trying to figure out what size to go with my adapters?
    Quote Originally Posted by clifforddd View Post
    Check out the wheel thread.
    You other guys should post this info up
    whats the thread title? or can you link me? cheers
