Yes you need to remove the entire trim as the back of it is rounded and needs to be hooked into position. You will damage it otherwise Sorry to give you the bad news.
God damm this has got me stuffed!! got rear of roof lining down enough for access to replace the antenna mount but getting it back into position is proving the be an *******!
Please don't tell me I have to make the lining loose in all directions so it can be pulled rearward, up and then forward so it will hook itself to the metal ridge ---- I can't see any other way.....
HELP
Ok got the roof liner loose enough to get the rear of it into position, fairly easy job all up took me about an hour. Those plastic covers on the baby capsule anchor points look a big marked/sun damaged thats the next project when I work out how to take them off as they're on pretty good....
