Results 1 to 10 of 11
Thread: 4mo Bora rear swaybar hitting on driveshaft :(
    Dec 2012
    Hey guys
    Installed a whiteline 22mm rear swaybar into my 4mo Bora the other day. All went well until I could hear something banging everytime I go over a bump..
    The rear drivers side driveshaft is hitting the end of the swaybar? Doesn't do it on the passenger side.
    I've tried the swaybar on all 3 stiffness settings, and same problem everytime..
    Pulled the swaybar out, and re-installed to make sure it was in properly.. still doing it
    So now I have no idea whats going on
    Does anyone have any ideas? Car is stock height/stock suspension. Nothing appears bent or damaged
    Pics:
    Drivers side. Can see where it hits and has rubbed off the sticker
    Passenger side is perfect. not rubbing, no noise at all
    Jul 2010
    Canberra , ACT
    mine didnt do that .. is it the bar that's rubbing ? or is it the end link that's rubbing ?
    you may need an adjustable end link ..
    Volkswagen R32 MKIV 3.2 > Suspension > Sway Bar > ES#2497385 Gloss Black Adjustable Swaybar End Links - Pair - 108GRVBLK
    Sam
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
    Aug 2007
    Five Dock, Sydney
    This might sound Capt Obvious but is the bar designed for 4Mo or FWD mk4? I've got a Neuspeed 22mm rear and it hasnt ever knocked, even with slight lowering.
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Jul 2010
    Canberra , ACT
    it's the only rear bar whiteline makes for 4motion boras and R32's as far as i know .. i have it in my car. . not a single issue
    Dec 2008
    Sydney/Canberra
    FWD has a torsion beam rear end, so the swaybars are not compatible.
    Adjustable links sound like the go.
    Have you spoken to Whiteline about it?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2012
    After pulling out the swaybar, it turns out its actually bent
    Pretty significantly too
    Gonna call the company I bought it off on Monday for a replacement. Hopefully it goes smoothly...
    Because there's no way I could have bent it. Gonna argue that it's a manufacturing defect or it got bent in postage
    Who u buy it from?
    I got a defective front one from whiteline and they flatout denied there was a problem with them even though there was 100s with the same issue in the UK and they had done a recall over there.
    Dodgy as if you ask me. Hopefully you have more luck
    Dec 2012
    Bought from MRT Performance in Sydney
    If they don't replace it I'm gonna cause such a fuss haha. Didn't pay nearly $300 to get a bent swaybar..
    Whiteline are supposed to be a premium product as well
    Quote Originally Posted by mhemming View Post
    Nar they are rubbish. Check around on the net to see if you are the only one
    Jul 2010
    Canberra , ACT
    how did you go with it ?
