Results 1 to 7 of 7
Thread: 4 motion fuel pump
    Q.L.D Sunny Coast
    4 motion fuel pump
    Hey all my fuel pump went a couple days ago and from vw its dear as hell. Anyone know of a place thatll have one to suit a bora 4 motion. Maybe a performance one if possible
    Oct 2010
    Mildura, Victoria
    Re: 4 motion fuel pump
    Drop into an Autobarn store with your engine code and they should be able to order you a new fuel pump
    Engine code will be something like AGU or AKL for example
    Sent from my GT-I9305T using Tapatalk 2
    '01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
    4 motion pumps are different as the tank is a saddle over the driveshaft.
    http://www.ebay.com.au/itm/New-GENUI...item23247ec947
    It'll look like this with the pipe that connects to the lift pump from the other side of the tank.
    If yours is really dead, I have the one I took out of my S3. It was still working. Might get you back on the road while you sort something else out?
    Jul 2009
    Geelong, Victoria
    Don't know if the bora is the same, but you can get the pump motor itself out from the housing and bits around it. The electric motors by themselves are about a hundred bucks. Autobarn should be able to get you one. I got one from Repco for the mk4 golf
    They are different Stan. That short pipe goes direct into the pump, which is different to the 2wd ones.
    Jul 2009
    Geelong, Victoria
    Cheers Gav, looks like a new pump then
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Apr 2008
    Check if ECSTuning have the one you want. If so, I can help.
    Nothing to see here...
