Results 1 to 7 of 7
Thread: 4 motion fuel pump
    Oct 2010
    Mildura, Victoria
    Re: 4 motion fuel pump
    Drop into an Autobarn store with your engine code and they should be able to order you a new fuel pump
    Engine code will be something like AGU or AKL for example
    Sent from my GT-I9305T using Tapatalk 2
    '01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
    4 motion pumps are different as the tank is a saddle over the driveshaft.
    http://www.ebay.com.au/itm/New-GENUI...item23247ec947
    It'll look like this with the pipe that connects to the lift pump from the other side of the tank.
    If yours is really dead, I have the one I took out of my S3. It was still working. Might get you back on the road while you sort something else out?
