![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Coralon
I have been doing a little research and have found the possibilty of the r32 engine being the same as the 03/04 touraeg v6, mk1 TT 3.2 and also the a3 v6 (hints at the possibilty of the cayene v6 also being the same donk with porche goodness). So onto the meat of the topic...
The question: Does anyone know if all these cars do indeed use the same engine (even if there are slight tuning/cam differences) as it opens up a whole lot of possible sources for a doner and is it possible to to just do an engine and ecu swap if the new engine has immo defeat run on it?
They are all essentially the same block with different oil filter mounts etc.
The inlet manifolds are different depending on whether they are longitudinal or transverse as well (not an issue with a turbo
The Porsche and Audi ECUs won't work in VW however due to other differences, not just the immo.
PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
