Results 1 to 10 of 30
Thread: FukenBroken V6 Bora
    Mar 2011
    Dandenong, VIC
    FukenBroken V6 Bora
    Hey guys well im nero 17 years of age and well this is my first Vw , decided to get something diffrent after owning 2 fwd sr20 powered nissans and right now cant seem to get enough of it its a 2003 Vw Bora V6 4-Motion which i recently purchased for real cheap ( reason later ) so lets get on with it
    first sight
    back at home
    18" audi tt Replicas(correct me if im wrong)(not currently fitted)
    a bit of messing about with parts from my old car ( there is a serious reason why the whole front end is taken off )
    and now lets get to the serious part
    well being 17 money does kind of suck money wise so there was no chance in hell that i could have bought one of thease bad boys outright, but luckily for me my dad used to be a mechanic and ive been around cars and been repairing them since well forever. assisting in whatever my dad was up to weather it was something simple like replacing brake pads to something complicated like a engine rebuild so this brings me here a low budget and big dreams so what do you get ? ...
    well i chose not to give up big dreams and have some fun along the way ( or i thought so )
    at the auctions the car was described as not running so i thought it could have been a realy simple fix as the car at first glance appeared to be very clean ......
    much to my dissapointment it turned out to be more serious then i had originaly thought so i started ripping the healthy looking vr6 appart
    top end revealed to be unscaved and all in imaculate order so going on to the bottom end revealed a little more then i thought
    the suspect of this turned out to be a snapped first conrod , cracked first piston, bent #2 and #3 conrod aswell as a damaged engine block ... no doubt about it no ressurection happening here .. so that leaves me here with a whole bunch of hopes and dreams and a awaiting engine bay ...
    at the moment i have managed to find a donor BDE VR6 engine with low k's on it but cant afford the bugger right now so i guess just keep saving my my poor excuse for a paycheque .. hhehehehe
    thanx for reading hope to see some positive imput
    Point Cook, Vic
    was it sold as a flood damaged vehicle?
    Id say there are going to be quite a few cars popping up soon with similar engine problems.
    Hopefully you can just plonk in a second hand engine and drive
    FOLLOW US ON FACEBOOK
    Mar 2011
    Dandenong, VIC
    unfortunately on the listing it was just described as not running and a repairable write off nothing to do with water damage hence why i bought it , but without a doubt water being sucked in was the culprit here ....
    everything seems to be okay besides the engine ofcaurse so it should just be a swap and go operation
    kind of sad but im not complaining even after everything its still gonna cost a lot less then the normal selling price hehe cheers for taking the time man
    Nov 2006
    Largs Bay, S.A.
    Have you had a chance to check out the electrics as yet? I'd be surprised if there weren't a few gremlins if it's been flood-damaged ... Looks nice and clean though
    Dec 2007
    GLENHUNTLEY,VICTORIA
    It was involved in the floods,and its previous owner is active here,having replaced his much loved Bora with a TDI Jetta...
    May 2010
    Perth
    ouch!
    previous owner of my old bora hydrolocked it too driving through a deep puddle, was in the region of $3k for a VW dealer to fix it, but looks like yours is worse off.
    Should have put a 3.2 in instead
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Mar 2011
    Dandenong, VIC
    Hahaha my thoughts exactly when i realised the engine was stuffed lmao but then i realised that besided being uber rare its going to be super expencice and aswell is gonna need a engineeres certificate so .... doesent matter i think the 2.8 will be more then enough after a zaust set up cold air intake and a retune ..
    Apr 2008
    Quote Originally Posted by Neroo View Post
    Not hard to get it engineered. There's a running R32 long motor in the trading section for $4k at present...
    Nothing to see here...
    Mar 2011
    Dandenong, VIC
    well after looking around my brother insists that the engine is usable so i guess a rebuild is in order , quick question , are the 12v vr6 pistons and rods same as the 24v ones ? i was thinking alongside .05 oversize 12:1 high comp pistons if their available anywhere and forged or original rods ??
    Jan 2010
    North Shore
    3.2l motors were in 3C passats too (made more power than the R32, less chance of being thrashed and possibly cheaper). Mk5 R32s and 3C passats have different engines to the older mk4 R32s though so not sure how much would swap over.
    Really I'm disappointed in the people telling you to go 3.2L. You should be going 3.6l from an R36.
