Results 1 to 10 of 19
Thread: 24v VR6 AUE
    Kellyville Sydney NSW
    Question 24v VR6 AUE
    I own a 2001 AUE coded 24v vr6
    and looking for a tune and maybe even cams and few other engine bits
    as I'm aware AUE engines are harder to get performance Engine parts as they were built a tad different
    cheers in Advance
    Passion Garage
    - Grab Stickers/Merch - We can also source parts, refurb wheels, install Coilovers -
    Jun 2011
    No cams available.
    Don't think the ecu is flashable either. Probably wrong on that though
    No cams available.
    theres only one company that flash them and they're in the UK but i was wondering if there was anything other than cams. and also anyone know of a good company that make vr6 headers in 3inch ? or should i just get them custom built !!
    Passion Garage
    Gold Coast
    We offer a tune for that particular model the gains arent very impressive being a non turbo....the remap is carried out by removing and reprogramming of the the chip in the ecu..old skool style
    http://www.superchips.co.uk/search?m...1&variant=1564
    i also own a bora 4 motion and to be honest i havent even thought about investing even at trade price...
    Jul 2011
    Quote Originally Posted by Euro Remaps View Post
    This is the kind of information you need to hear from someone like this not after any money. Not many like that anymore, It's an honest call not worth spend money
    On very minor gains. If your keen on spending money do a 3.6 liter conversion or go turbo!!!!
    Quote Originally Posted by grtuned View Post
    Yea brother well if thats the case i think i won't bother, il do my headers and exhaust for now just so its less restrictive and fix up my intake a little, got a ****ty pod filter on atm
    yea a 3.6LT was in the plans if not a 3.2TT once I'm off my P's or close to it
    Passion Garage
    Jun 2011
    Don't do headers.
    Port the exhaust manifolds, have a local shop make 2" downpipes and a 3" exhaust
    Apr 2006
    VW Race HQ - Sydney
    Thats because they havent played around with the engine to know that they are quite a capable engine
    The main advantage is that they dont run the proper VVTI which has the cam gears as part of the VVTI limiting what you can do to the camshafts . The AUE engine runs the older more conventional camshafts which you can have made to whatever specification that you want . You can use the remainder of the Valvetrain out of a 3.2 mk4 R32 engine to get bigger valves . The head casting is different so you cant swap the heads over and run the older style chain (unless youre willing to weld the new head ) . If you arent chasing a 9000rpm engine with 280+ degree cams then the easiest would be to source a mk4 3.2 with engine bay wiring harness from either an R32 or a later 2.8 Bora and an ecu to suit . A 3.6 presents a bit of a nightmare in such an old car as its FSI so you'd need to run a different fuel rail not to mention it runs a non-return fuel system with a different can bus signal .
    Bug_racer supports the rebellion of the euro revolution
    Don't do headers.
    think this might be the way to go for my exhaust then, ever heard any issues after porting the mani ?
    Passion Garage
    Quote Originally Posted by Bug_racer View Post
    yea i think the go will be wait til Ive got another daily and i can put the bora in the garage a do a r32 NA build all motor or Turbo
    i think if i was to go NA means i can run ITB's do forged pistons, massive cams, bore the block out and new everything in-between really, new fuel rails, but keep it street worthy and haldex controller as well, would go well
    if turbo though il go twin turbo as lag is **** and I'm not going for stupid large power gains and twin turbo just sounds cooler tbh
    Passion Garage
