Just a word in here.... I was driving my car and it would intermittently cut out like it was starving of fuel, then give it 5 mins and it would be fine to drive for a while. I quickly got the ****s with this problem. It ended up being the C.A.S. I know that the Mk4's are diff to my MK3 but the new Mechanic that fixed my beast said quite often you get a false negative with the VAGCOM and won't show up the C.A.S error. Usually the coating on the wire starts to crack and split, the heat in the engine gets to the sensor and shuts it down. In mine however the plastic connector that joins the 2x 2-3mm probes to the cable had cracked/oxidized/crapped out. The probes are Copper covered Iron so when the heat gets into it the copper expands and renders the probe faulty. Don't quote me 100% as i'm still a NOOB. But thats my recolection of the conversation, I was just estatic to have my car back and driveable lol. Also probably didn't help that this happened 150 k's from home on the way to a family funeral.
Anywho the C.A.S in the Mk3's you need to usually jack the engine up out of the front engine mount and remove the oil fliter to get to housing. I say run with it you might spend more money replacing a not so necessary part but saves you doing it later.. Common prob in MK3 & 4's.
Good Luck
Rising Blue MY10 Passat R36
BLACK '97 Mk3 GL 2.0L
White '82 MK1 Cabrio 1.8L
Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
