Results 1 to 10 of 24
Thread: 1.8t very rough idle/miss
    Nov 2006
    Hey guys,
    My car's idle has never been perfect, usually varying 50rpm while sitting around but lately i've noticed that it tends to seem like it missfires/drops a cylinder (and the revs) then comes back up.
    It has gotten alot worse in the past few days!
    Sitting there idling it will missfire/knock, revs will drop to 500 then it will compensate and hit 1000 then back down to 800. Rinse and repeat.
    When coming off the throttle in gear or in neutral (at all, even just a tiny touch) the revs will drop as far down as 200rpm, then come back up to 500 then missfire - then hit 800 and then back down etc etc.
    I reset the computer and it did its throttle body calibration and it was fine for a short while but after some hardish driving it went back to having dramas.
    Can anyone suggest possible causes? It only has dramas when its idling it would seem, although last night it felt like it had a flat spot/struggled at about 1800rpm.
    Mar 2007
    sydney
    Quote Originally Posted by SoVeReIgN View Post
    Hey guys,
    maybe maf? wont you need to data log it
    mk4 the mods begin for round 2 hahahha
    Nov 2006
    Quote Originally Posted by DUB 20V View Post
    Ah the MAF was replaced about 10~15ks ago but I guess it could have gone again aye.
    It isn't going into limp mode or anything though, I might have to disconnect it and see how it drives.
    Mar 2007
    sydney
    yeah maybe, or maybe o2 sensor?
    gpk_gti Guest
    sounds like maf to me!!!
    I HATE MAF's!!!!!!!!!!!!!!!!
    Mar 2007
    sydney
    Quote Originally Posted by gpk_gti View Post
    hahhahaha i dont have a maf yay for me,
    Aug 2006
    how do you run d car without as MAF? can it be done for our cars?
    Dec 2007
    Auckland, New Zealand
    Stick it on the vag com and see if there's any errors, maybe reset the ecu and realign the throttle body. I doubt realigning the throttle body will help in this case but its worth a try
    gpk_gti Guest
    maf doesnt come up!!! ask h100vw... our resident maf expert!
    Dec 2007
    Can check Lamda figures though
