Results 11 to 20 of 24
Thread: 1.8t very rough idle/miss
    Aug 2006
    Quote Originally Posted by DUB 20V View Post
    hahhahaha i dont have a maf yay for me,
    how do you run d car without as MAF? can it be done for our cars?
    Quote Originally Posted by 1DUB2C View Post
    Haltech aftermarket ECU/computer
    Yes it can also be done to your's using the oxy sensor and knock sensor to calculate the air/fuel ratio etc.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Jun 2007
    Dirty West!
    I think he had suspension work done to his car...
    Sound like MAF mate...
    Sep 2006
    Australia?
    Dave has done something to the car lol. Didn't you have some more work other than suspension done to it, I could have sworn you told me at the BBQ.
    I'm not trying to disagree with any of the mk4 owners but what about the throttle body? Maybe dirty causing these problems?
    gpk_gti Guest
    I went through many different scenarios and fault checking when I had issues.issue 1 was a faulty 10 month old maf and a very small boost leak.But I also changed the lambda probe sensor,very hard for that to be faulty..there were no codes coming up btw.....
    ive still got a spare lambda if you want.....
    Jun 2007
    Eastern Suburbs Melbourne
    as i've discovered recently, any small vaccum or air leak, can cause havoc, so I vote MAF, if not that O2 sensor, then depending on the work you had done, all the new joins/seals are all sealed up tight!
    i like volkswagens
    Camden, Sydney
    Ignition control module very common on these cars. Wont show a code, or will show up as coilpack
    I have a test unit if you come past. And can get you a new one lots cheaper than VW
    Aug 2007
    Quote Originally Posted by 99gti View Post
    You still need to calculate the amount of air entering the engine. im guessing Haltech uses a manifold absolute pressure (MAP) sensor instead of a MAF sensor.
    Jul 2007
    Brissy
    I had a vacuum leak in mk mk4 and the idel was way rough. I found a hole in the pipe which runs from the throttle body round to the brake booster. A quick patch fixed this up.
    Also APR chpped 1.8Ts can have a rought idle when the aircon is on, pretty common but not as rough as a leaking hose.
    Nov 2007
    Melbourne, Australia
    Faulty maf; O2 sensors don't cause rough idle
    2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
    2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
