Originally Posted by
Major Tom
Yep Gav it'd be 2.75" or 3" right through, I will measure tomorrow. Going to chuck it in the backpack and ride over to Albion Mufflers tomorrow and see if they can install a flex section and weld it up.
The coolant part that broke was on the on the transmission side of the engine, above the starter. P/N 1J0121087A, which I will order from Austral tomorrow.
Thanks for the advice re oil/coolant lines. I was thinking the same thing. Disconnected the oil line from the filter housing so that I could wiggle the turbo enough to get an allen key into the banjo bolts on the turbo. Exhaust manifold is still in place.
Been a long night in the emergency department after the cat back fell on my fingers. Nothing broken but some swollen joints to enjoy!
