DW pump (thanks for the tip Lito!) and new level sender fitted
I could use some advice - the new ECU is immobilised......I haven't pinged it yet with VAG com but I'm guessing the AGU was IMMO2 and the BVR is IMMO3. I've read that VAG tacho can sort this, anyone done this already who might be able to advise? So frickin near now......
Gavin h100vw would be the man to speak to about ECUs.
Cool, thanks for the info. Once I get my **** together I'll ping him a msg. Fingers crossed the IMMO versions are the same as I don't have the code for the 'new' ECU.....
Originally Posted by
simmo675
you take your seat out when you mounted the peddle box..your ballsey going straight into it,give you that..im planning on-if I do- rigging it up out of the car to see if i can fire it up firstly..regardless top effort bruv
DEEP POCKETS NEEDED
Nice work, good to see some more people doing the me7 conversion!
- You may not post replies
- You may not edit your posts
Forum Rules
