Good question! Looking on here it seems like the custom code option is the least labour intensive. I see you've gone for a re-wire to go 7.5. How much work is in that? It makes some sense to go that way too but I cant afford to keep fiddling. Maybe go custom code now and swap out later
I still had to do something about the air con pipes, and the mostly useless heat shielding.
so the air-con pipes came out and were re-worked by Autofrost out at Milperra. Actually I should mention that I'm now working on the car at MotorRetro in Seven Hills - the boys are ex-TAFE teachers and after they closed the North Sydney automotive department they started the MotorRetro business in January - they do metalworking courses and classic car and bike restoration and modifications. If anyone in Sydney is looking to learn metalworking or welding they are the guys to see. Anyway its great to be working above ground, with natural light!
I digress - we ran some weld wire in the new pipe location as a template and the re-worked pipes came back bang on. I got them to run a flexible section over the top of the master cylinder so I could get to the reservoir and bleed screws later.
So with Vaughan's help we fabricated a custom downpipe. Me on the hacksaw and Vaughan on the TIG.
Test fit on the fab'd downpipe was encouraging:
but still tight!
Finally settled on the wastegate out and down screamer style we'll see eh?
What wasn't immediately obvious was the water line to the TIAL MVS bumps the bulkhead; the build up of the exhaust v-band, coolant banjo and clearing the downpipe with the dump-pipe adds up to just a little too much for the space available.
so I ended up re-plumbing the coolant feed to the turbo and wastegate and pushing everything in toward the block as far as possible. Motorsport Connections are just around the corner, and they have all the speedflow -AN fittings and hose in stock.
Pretty much done here.
very nice!
what size turbine housing are you using? looks like you are using an adaptor plate at the bottom of the flange to the mani???
t25 to t3 (as i know that mani is only available in T3.... so annoying)
also - without the heat shield on top of the turbo - how much clearance is there above it?? looking at a mani without the EWG but maybe add this?
T3 to T3 Turbo Flange Adapter, Flanges, XS Power Inc.
Very neat
I also have top mount, but a cheap Maximizer manifold that I cut the T3 flange off. You can buy adapter plates, but I see that as another leak point
Interesting to note the water fitting comments... something I had better check
Honestly knosing now how straight forward it is i would have swapped to me7.5 a long time ago. As long as you get a decent condition harness (no split wires, cracked insulation, etc) it drops right in like factory and works like oem retaining all factory options, except silly stuff like traction control but if you want to add the sensors and modules in that can be accomplished.
PM'd
