Results 1 to 10 of 15
Thread: 1.8t Diverter valve questions...
    Jun 2006
    Orange NSW
    Hey guys,
    A mate of mine has a 2002 GTI, and wants a bit of noise for the cool boost dump type thing. He is a registered user on here but far too lazy to get off his bum and ask the questions himself, so here i am..
    What are the options for replacing the diverter valve to something that makes a bit more noise? I don't want to change it to a straight up blow off valve, because (as some/most of you know) that upsets the tune with the MAF telling the ECU that the engine is consuming more air than what it actually is...
    So.. options please..
    Thanks, Preeny.
    Feb 2008
    The Forge Duel Port Diverter Valve diverts 70% to intake, and 30% to atmosphere It wont upset the MAF, and makes some extra sound. This is what I have on my Polo GTI.
    Turbo Smart have their Kompact series, which is the same, but about $100 more expensive.
    You can get the Forge one through Rennenhaus or through Shaneth...I payed $220 for mine delivered.
    This is the Forge one...
    http://www.forgemotorsport.com/conte...duct=FMDVSPLTR
    There are DV's that have an adjustable blow off to atmosphere. You could open it up a bit until you get a fault code then go back a bit.
    I can hear my forge inside the car, not sure what it sounds like outside though. I have CAI fitted though and supposedly that makes them a bit louder but I am not convinced.
    Changing the spring in the DV makes the sound different too. I do have 28PSI though
    TBH unless you have VAG-COM to clear the faults it could turn into a load of hassle.
    I'd just get an alloy recirc valve and leave it at that. Having the car flashed would help the noise as there would be more boost to divert.
    Jun 2006
    Orange NSW
    Quote Originally Posted by Blitzen View Post
    I like the sound of that.
    Tom purchased a wastegate bleed type boost controller the other day and we had a bit of a play and wound it up a bit, which obviously made the boost dump/divert louder. So now he wants louder again. Haha.
    Any other people have any suggestions?
    Sep 2007
    These adjustable BOV's from GFB are pretty cool.
    The Stealth FX is manually adjustable by turning the top to adjust between atmospheric and recirculation ratios.
    http://www.gofastbits.com.au/index.p...ion=stealth_fx
    Or if you want to turn it up at the twist of a dial...
    http://www.gofastbits.com.au/index.p...n=deceptor_pro
    Oct 2006
    option b
    when you get a CAI (aem etc) it will echo through.. so that + stock dv or recirc will make noise regardless.
    Sep 2007
    I have the APR R1 and even with just a modified (read: shaved) airbox, you can hear it.
    It's certainly noticable in the car, not sure how loud outside the car though. Then again, I personally don't want to attract that kind of attention.
    Jul 2007
    Brissy
    Quote Originally Posted by fuzion View Post
    option b
    Yep BMC CAI has cool echo, don't need to worry about atmo venting (ticket time) or MAF faults pain in the
    Forge 007 is a good recirc valve which clamps quickly to help keep the boost pressure. BOV for attention whores, recirc valves for performance.
    Jun 2006
    Orange NSW
    He doesn't really want to spend much money (can't afford to etc etc.. I think he's just tight), he just wants it a little noisier. Some good ideas there. I was even thinking of having a look at it and removing the silencers they have in the diversion tract.
    Canberra
    Swiss Cheese mod will get him some extra noise, it's free and many 1.8T "experts" agree it is one of the best intake mods.
    Snowy
