Results 1 to 3 of 3
Thread: How to clean my instrument cluster 2003 Bora 4mo?
    Jan 2011
    Bundaberg
    Hi Guys,
    Apologies if this is obvious to some, I have read some warnings about immobilisers being messed up...?
    I want to clean the dust out of the inside of it and make it crystal clear like new...
    Can someone point me to a post or guide to how it is done?
    Cheers,
    Scott
    I used a air gun and som compressed air to do my Bora, then used a plastic polish on the outside. Wasn't perfect but so much better.
    Can't see why you couldn't remove the cluster then remove the plastic from it...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2011
    Bundaberg
    Thanks, that would be pretty easy - I did find a couple of write ups in the end, and yes, you pull out the cluster completely, and unscrew the Plastic screen from the back - everyone just says be careful not to scratch it... we'll see how it goes.
