Results 1 to 3 of 3
Thread: 1.6 SR TB clean out
    Jan 2010
    Keysborough, Vic
    1.6 SR TB clean out
    Hi
    I've just recently done a service on my 2000 mk4 Golf which has the 1.6 SR engine, and decided while I was at it I would give the good old TB a clean wiht some Carb cleaner. as it turns out there was lots of gunk which was stripped out and burnt off by the engine. (ie. tb still attached to engine)
    Then with some hesitation it started and noticed the idle was out of wack! It would flactulate from 1200 through to 1800rpm, took it for a drive and still didn't go away.
    I thought that maybe the carb cleaner might have dislodged some crap and bloacked sometihng else, so I gave it another clean with the engine running and also decided to clean the AFM, this time around it worked very well and the revs have now stabilized, tho now when it's being driven and come to a halt it stays just above 1000rpm and takes some time to come back down to 900 or so which is normar idle speed.
    I'm lending my self to believe the TB needs an adaptation since it needs to re-learn its positioning and this is to be done with VagCom???
    sorry for the noobiness but thish is the first Golf I've ever owned and I have never used VagCom before. May I also ask if there would be any shops or specialist that can do this and what would costs for such thing be???
    I have done this to previously owned cars in the past with no major hassles, one of which was a 90 model Honda Integra which made a huge difference in economy and response, hence doing the same on the Golf was the idea at the time.
    Replies greatly appreciated in advance.
    Alex
    Jan 2010
    Keysborough, Vic
    Well good news!
    Have driven the car both today and yesterday and she's running back to normal....
    I think something might have been blocked up and needed tine to be burnt off, from experience I think it might have been something to do with the o2 sensor, maybe when the carby cleaner and crap got burnt through the engine it coated it with gunk???
    anyways all good now
    May 2010
    I've just done this to my wifes car and am experiencing similar high idle (1,500 rpm in neutral and temp showing 90 degrees).
    Idle also seems to be hunting a bit, just took it around the block a few times but am hoping it goes away (like your did) after a decent drive.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
