Results 1 to 10 of 10
Thread: 04 Bora - Overheating AGAIN!!!!!!
    Angry 04 Bora - Overheating AGAIN!!!!!!
    Can anyone help me.
    Our Bora intermittently overheats.
    The fan works sometimes then doesn't other times.
    The mechanic replaced the thermostat thinking it could've been sticky, also the temp sender was replaced. Quite costly it was.
    And now it's doing it again. Is there a fan relay or something similar that could be causing this problem?
    I feel that I have a Fiat under the body.
    As this is my Wife's car, she is ready to throw it off a cliff and buy a japanese car. Eeeeek.
    Any help would be much appreciated. Friends and forums have all said that the Bora is generally bullet proof.
    Yogiferrari
    AM PRODUCTIONS
    Photo and video services
    Melbourne Victoria
    www.amproductions.com.au
    There is a fan relay box under the bonnet. It's by the battery IIRC. They do play up sometimes. There is also a few fuses on a bracket over the battery, I have seen them melt the housing. Check them out too.
    Camden, Sydney
    Yeah there are 3 wires with fuses coming off the relay panel at the back of that little fusebox under the bonnet. On top of the battery. They goto a connector.
    Next time the fans are not coming on, squeeze the connector and they should start.
    An auto electrician can bypass the dodgy connector with an inline fuseholder, or buy another fuse box.
    St George/Sutherland, Sydney
    Have you tried the fuse for the cooling fan and air com?
    Mine has blown a couple of times resulting in Mega over heating. On my golf the fuse is above the battery in a little box. Its the one on the left.
    May 2007
    Moonee Ponds
    Yes,
    it looks like this happened to my car in a past life. As one of the blade fuses had melted its surround
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Quote Originally Posted by qsilverza View Post
    Yes,
    And another one! I've suffered the same problem.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Jan 2008
    Ascot Vale
    overheating
    Was it a mechanic with VW experience?? Do yourself a favour and send vw_tech a PM.. he won't stuff you around..
    Jul 2005
    have you tried a new water pump?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Aug 2007
    Water pump -will have different symptoms, like Loon has mentioned the fuse block can be bypassed if you are stuck. These are on the shelf at Dub or Audi. Same part on an A3.
    Alba European
    Jul 2005
    Even a busted water pump can can behave around town then play up on a big hill or when it's been driven for a while, see it every week.
