Results 1 to 7 of 7
Thread: 03 Bora 4 mo .. need to take drivers door skin off .. how hard!
    Jul 2010
    Mitcham, Vic
    Hi all. I need to take my drivers door skin off to vaccum out glass from a break-in. Glass replacement guy didnt do it (why are there no good tradesmen anymore???).
    So, how hard it it to take this off to do the job?
    Cheers all ..
    Bruce
    03 Bora 4Motion ... luv it
    Jun 2008
    Cronulla, NSW
    I'd be very interested to explore this as well as I've been toying with buying some Dynamat and skinning the doors and firewall with it.
    Whats our stock noise insulation like? I remember on the WRX...ummm.... there was none. Dynamat made a humongous difference.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    If its the same as the passenger side its a piece of cake, I had mine taken off one. I didnt do it, but it was done in a few minutes right in front of me. Even drove around without it for a few days
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2010
    Lesmurdie
    Easy as pie.
    Unscrew 3 torx at bottom of door, Unscrew phillips screw near tweeter. Unclip the door handle pull by pulling the inside plastic out and then gently pulling up. This will uncover 3 brass colour screws that come out and then just gently pull.
    taligentx.com: Passat - Door Lock Mechanism Repair
    VWVortex.com - DIY - Removing front door parts (door panel, door unlock handle and sideview mirror)
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2008
    Vic
    It's really easy once you know how to do it, as BDS listed the procedure above.
    There's no real "deadening" on the factory doors, but these aren't a weak point for noise in the Bora.
    The floor has 1" of thick wool underlay, and then a layer of mass loaded vinyl (MVL), underneath the carpet.
    This works exceptionally well as a noise blocker.
    The weak point's ive found are the mirrors (they're not the most aerodynamic and quiet), and the windscreen.
    Unfortunately you can't really do much about the windscreen.
    I've contemplated dynamatting (or better yet use MLV) on the roof but I don't think this would reduce noise considerably.
    If you have any problems let me know.
    I work round the corner and can give you a hand, should only take 5mins to get the door off.
    Nov 2008
    Northern Sydney
    Quote Originally Posted by Back Door Shenanigans. View Post
    Easy as pie.
    Anyone know if this is similar for the golf?
    2010 Skoda Octavia vRS Wagon
    Mar 2010
    Lesmurdie
    Quote Originally Posted by sir_camel View Post
    Well the top ones from a passat, All mk4 share pretty similar interiors i would imagine its the exact same.
