Page 17 of 21 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 207
Thread: My Corrado G60
  1. #161
    Suffolk UK
    No big secret ! To get them to flash orange i ended up pin striping the indicator lenses like this
    I used Red lens and bulb dye spray paint by a company called 'specialty'.
    I didn't want to use this stuff cos it comes out of the can terribly, i found it helped to keep shaking it every 5 seconds but it still squirts out rather than spraying. The best stuff is made by Savage or Foiltech, but i can't find it anywhere in Australia, i ordered some from the UK but customs binned it as you need a liscense to import paint.
    I experimented on one of them and found if you build up the layers (about 4-5 coats) you can sand it back with 1200 wet and dry until its flat again. The mistake i made last time i done it was not clear coating them, they faded back to orange in a year or so. This time i used an Enamel based clear coat on them, about 3-4 thin coats, then cut them back with 1500 wet and dry then T-Cut, then Polish.
  2. #162
    Feb 2007
    Quote Originally Posted by carpoid View Post
    So how did they come out?
    MK1 GLS 3door
    A4 B7 2.0T
  3. #163
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Spyda View Post
    dude, go back one page...
    (page 16)
    i like volkswagens
  4. #164
    Jan 2007
    Looks great!
    Hmnn now all I need are some GL/CL tails and match up the blinkers. Where did you purchase the bulb paint from?
  5. #165
    Suffolk UK
    Cheers guys, you'll find that lens dye in Burson and errrr ... can't think of the other place, not Repco or Supercheap, the other one, whats it called
  6. #166
    Jun 2007
    autobarn?
    (filler)
    i like volkswagens
  7. #167
    Suffolk UK
    autobarn?
    (filler)
    Thats the one
  8. #168
    Aotearoa
    Hi Carpoid, nice work your rado is looking sexy! What are the specs of your 16" RS? I have recently bought some, but are 4 x 114 and can't be redrilled to 4 x 100. Am trying to find some 4 x 100 16x7". Cheers.
    1990 16v Corrado - Helios Blue
  9. #169
    Suffolk UK
    Hi mate, my new RS are 17", 5x100.
    The 16's i had were RS 003's, they are 4x100 ET25 with the correct Centrebore at 57.1mm, they are a factory fit, but they don't come cheap unless you are lucky - mine went for $2950 on eBay.
    Pics of the 16's.....
    Another option for you would be to get your hubs redrilled and tapped to the matching PCD, a guy on the UK Corrado forum has 5x100 hubs with 5x112 drilled on them too so he can run both PCD's ....
    What offset are yours ? No room for adapters ?
    Matt
  10. #170
    Suffolk UK
    What looks better ?
    16's
    or 17's
Similar Threads
  1. Replies: 94
    Last Post: 18-04-2006, 07:48 PM
  2. corrado vr6 same suspension as golf vr6??
    By Red Mk1 in forum Corrado
    Last Post: 08-02-2006, 09:00 AM
  3. Corrado 1994 VR6 4 sale in New Zealand
    By aussieg60 in forum Corrado
    Last Post: 10-01-2006, 03:39 PM
  4. Corrado spotted !!
    By OEM G60 in forum Corrado
    Last Post: 11-12-2005, 11:04 AM
