i swapped a b4 passat moonroof in to my 93flats for sale in thane westcorrado cause the oe sunroof was bad. everything installed nicely and very easily. however, when i water checked it i’m getting leakage where the back crossmember drain is that connects driver side to passenger side. but, it looks like water is running down the underside of the roof line (in the interior) and then property in mumbai dripping further past where the drain catch is. anyone know how to sort this issue out? am i missing a part? if i’m not making sense i can take pictures if it will better describe the issue. Thanks builders in dombivali
Not sure if this is a technical point
