Results 1 to 2 of 2
Thread: looking for some technical help regarding the sunroof
    i swapped a b4 passat moonroof in to my 93
    flats for sale in thane west
    corrado cause the oe sunroof was bad. everything installed nicely and very easily. however, when i water checked it i’m getting leakage where the back crossmember drain is that connects driver side to passenger side. but, it looks like water is running down the underside of the roof line (in the interior) and then property in mumbai dripping further past where the drain catch is. anyone know how to sort this issue out? am i missing a part? if i’m not making sense i can take pictures if it will better describe the issue. Thanks builders in dombivali
    CrookWatercooled Guest
    Not sure if this is a technical point
