Results 1 to 3 of 3
Thread: Corrado... Sticky pop up rear Spoiler>.
    Anonymous Guest
    What do u do If this happens???... can u overcome this problem?/
    imported_brackie Guest
    Could be a mulitude of things!
    Firstly...How lucky you are to have a Corrado! Are you in Oz? Popup spoilers are a bit like sliding sunroofs. Lack of lubrication makes them sticky. Check the runners first. Use a body grease (you know, the white stuff) as it's less likely to get washed off. My Peugeot GTi suffered from a sticky sunroof to the point where the (plastic) cable stripped its gears. Expensive.
    Camden, Sydney
    Yeah I`d go with brackie. Also check that the rubber is not catching on the spoiler when it pops up.
Similar Threads
  1. OEM 25th Anniv Front & Rear valance
    By jbot in forum Mk4 Golf & Bora and New Beetle
    Last Post: 21-02-2007, 08:59 AM
  2. Removing rear window mk2 gti
    By ausgolfer in forum Bodywork/Trim & Detailing
    Last Post: 19-01-2007, 10:13 AM
  3. Replies: 94
    Last Post: 18-04-2006, 07:48 PM
