Originally Posted by
pjondeck
Agree Howard, the alternative to the ZENEC if I decide to pull it out is the original RCD-310 or or have an RCD-510 which I may be able to get the Bluetooth module for. This would mean running with the Garmin GPS mounted on the dash again. The advantage of that is if there is a glare problem it can simply be swivelled away from the glare. I have found the "eyebrow" as you so succinctly put it does do the job fine, just need to make a prettier one if I stay with the ZENEC. If I have a choice of the ZENEC with a crap radio for $2100 or the alternative system I might as well go for the Chinese jobby with a crap radio for $380 odd I suppose.
cheers
Peter
Or buy a RNS 510 for $1180 and know it will work Put an eyebrow on it if glare is a problem
