Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Yellow Exhaust Warning Light.
    Aug 2009
    Hobart
    VW transporter, 128 kW, 2009 version.
    Some time ago I have the yellow exhaust probe warning light come on. I called the dealer who said just monitor it. It went out after a day or two. It has now come on and is staying on. what exactly does the light warm me of, can it do damage to the exhaust if it remain on, is it a dealer job to rectify. the truck is still under warranty so presumably it should go to the dealer?
    Any comments greatfully recieved.
    Shifter
    Sadie - 08 VW Dual Cab T5 Transporter 4 Motion (128kW)
    Adelaide hills, SA
    Look in this thread, you most likely have the same problem. http://www.vwwatercooled.org.au/f97/...ght-47372.html
    DPF pressure sensor. It is so common problem that I bought one from the dealer and it is in the glove box of our Tiguan, ready if we need it.
    Aug 2009
    Hobart
    Could be a similar problem, but it's the yellow warning ight which depics an engine. What is a DPF? Do I have one?
    Trip to the dealer required I think.
    Shifter
    Adelaide hills, SA
    Yes you have one, every T5 made after 6/2006 has one. It may be that it can't regenerate for some other reason, definitely see your dealer asap. See also diesel section of the forum there is some info on DPF as well.
    Aug 2009
    Hobart
    Thanks, have read the thread, now understand. I'd rather see a puff of black smoke than this anti pollution BS. Anyway off to the dealer.
    Shifter
    Aug 2007
    Delete it , tune it and have the DPF byte changed so the dumb ecu doesnt see it. Works a treat, i know ive seen it!!!!!!!!!
    Jmac
    Alba European
    Aug 2009
    Hobart
    Jmac, how do you delete it and change it?? Seems to me it does nothing but capture exhaust gas particulates, better in the atmosphere. Don't tell the Greens!
    Shifter
    Aug 2009
    Hobart
    This thing has got me beat! Just as i was goingto the dealer with the yellow light alblase, it went out and has not returned about a week now. Don't understand what is going on. Can these things repair themselves?
    Shifter
    qls
    had the same light come on, (it was going to dealer anyway) and it was the same as mentioned here a number of times a faulty pressure switch in the exhaust, however the light actually has (apparently) many sensors attached and it could be any of these, so who knows unleess it is plugged into a computer
    Jan 2008
    Sunshine Coast
    Given the DPF costs a cool $4500, and is considered CONSUMABLE by VW, I'd get to the dealer and have them pull the error codes that will be recorded. They will replace whatever is at fault, and you want the DPF to be regenning as it should, you don't want any less than the 150k they are supposed to last. If it is the pressure sensor Miro speaks of, you will most likely need VW to calibrate it, I've replaced mine and tried to recalibrate it with Vag Com, but it is doing weird regens still, and it's driving me nuts.
    I wonder if Jimmy can reset this bas#$rd?
