Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Won’t start after new camshaft
    Hey guys I bought a 2008 transporter 6 months ago now has 190,000 km and I have just changed the camshaft, followers, oil and filter because it was backfiring and put scrapes in the camshaft and followers were rounded a little,
    Typical car dealer bodging up cars...
    Anyway I can’t afford to take to Volkswagen to find the problem and need it for work
    It turns over but won’t fire, it was running before we pulled it apart,
    also the battery went flat during the time waiting for parts, my dad is pretty confident the timing is right (being a diesel mechanic)
    After about 5 seconds of turning over the oil pressure light comes on and beeps
    Any help would be greatly appreciated since we are lost for ideas
    Thanks in advance, John
    Also maybe the EPC light was on too
    Jul 2010
    Robina Gold Coast
    I had a golf diesel that used to do that if i had not used it for a while,
    but only occassionly i found i had to crank it for at least 30 seconds the oil light did come on but then it would start
    never found out what caused it ,
    Thanks Ian I stopped after 5 seconds was scared I would break it
    Gosford Central Coast NSW
    Not sure if you got it going or not but provided you are CERTAIN youve got the cam timing correct (turning engine over by hand before even attempting a start) then you'll just be waiting for prime in the injectors which can take a while. Dont worry too much about the oil pressure warning.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    I still haven’t got it going....
    we have cranked for ages and still nothing
    we suspect it might be the cam positioning sensor, so going to change that in a couple days and try again then
    Thanks for the feedback
    If you are looking at the engine from the front is cylinder 1 on the far right?? That’s the way we have done it I have a Haynes manual now and i think it’s right
    Nov 2014
    Are you getting fuel? No air lock in the pump
    sydney nsw
    what engine is it?
    2.5 BPC
    also if you are looking at the engine from the front of the vehicle is cylinder #1 on the far left? Or the far right? Can’t find much online
