Results 1 to 10 of 18
Thread: Windscreen Replacement for Multivan
    Dec 2006
    Kilsyth, VIC
    Looks like I'm in need of a new windscreen after a rock flicked up from the road and has left a nice chip and a 20cm+ crack (I'm yet to see it myself, but from the phone call I got it's going to be a replacement job).
    Of course it's rain sensing so is that much harder (expensive) to replace, (2010 Multivan). Who is the recommended repairer/supplier for glass for these? (In Sydney) The insurance use O'Brien so the process to use them is very simple, but I welcome any feed black people might have on them.
    Adelaide hills, SA
    I'm sorry to hear that, mate. The 20cm crack does always warrant the windscreen replacement. It hurts more when it happens on the new vehicle.
    Jan 2008
    Sunshine Coast
    I'll be watching with interest, I did my screen this week too...it's already spreading.
    Bit wary of a no name el cheapo insurance replacement....may actually want to ge genuine on this one!
    Dec 2006
    Kilsyth, VIC
    I was surprised to hear the replacement cost for the aftermarket unit, even with the rain sensing wipers, is a shade under $600. I always thought they were much more expensive.
    I have booked O'Brien for later in the week, will keep you all updated on how things travel.
    Mt Cotton
    I have a crack in my work van that starts at the bottom corner of the passengers side and has travelled to almost the middle of the drivers side but it has stayed right along the bottom 15cm up from the bottom all the way accross . It has been that way for nearly 18 months I just can,t be bothered as I do a lot of out of town trips with my work and I can gaurantee that if I fit a new one it will be hit the next day . I was recently pulled over for a RBT and the guy doing the test was fine but his superior made a big deal about the crack so while he was going on about it, typicaly I forgot to use common sense and I slid down sideways onto the seat until I could just see over the dash and I said to him that yes it was dangerous from down there as that was the only position that the crack was in eye view . The young cop was laughing but the older one just grunted and said I should get it fixed any way , I drove off smiling to myself and also thinking that I should not have tested his patience . Howard PS was stone cold sober
    Jan 2008
    Sunshine Coast
    Ferkin classic.....
    May 2010
    Kilmore, Vic
    Sunny I'm pretty sure it's a crack anywhere now, as the strength of the roof is impacted by the strength of the windscreen
    Hence the arguement is now a crack anywhere in the screen lessens the strength in the roof
    But I figure if you bother to get on your roof, worrying about a crack in the screen is just a little bit wrong priority
    Hawk, when you get your van back, check your rain sensor wipers as soon as you can
    The 2006 I bought a couple of years ago has an O'Brien replacement screen in it, but the rear vision mirror, with the rain sensor in it, was not sealed to the screen properly
    Sometimes it works, sometimes not
    I'm led to believe the new replacements screens have the sensor in them, so should overcome this problem
    Does anyone know this for sure?
    M
    Jan 2008
    Sunshine Coast
    I was of the understanding the rain sensor was just a photosensitive component in the big box that adheres to the screen, and needs a specific, bubble free bond so that it is only affected by rain drops on the screen immediately above it. The screen itself just needs to be clear. I have heard the VW screens are somehow "metallic" and the Tollway e-tag receptors have problems getting a signal through them. I think it's some sort of heat shielding.
    Dec 2006
    Kilsyth, VIC
    O'Brien claim it's the "same" but without the VW stamp on it... And don't worry about the rain sening wipers, will be the first thing I look at and check to make sure they work.
    Nov 2007
    QLD
    O'Briens replaced mine which had the radio areil in it, but no rain sensor. They verified which it was and the replacement was very good, as well as the workmanship and cleanliness.
    Brian
