Results 1 to 10 of 15
Thread: White Smoke from Multivan T5.1 biturbo diesel
    Dec 2016
    Shellharbour NSW
    G'day,
    Any help would be really appreciated. I am getting (mainly) white smoke on acceleration and am struggling to find out what is causing it.
    The biturbo needed to be replaced after it broke down. No air going through after the turbos failed.
    No loss of coolant.
    Now very little loss of oil, poss within the 'limits'.
    Good compression when cold.
    Injectors have been removed and independently tested, there good.
    PCV valve has been replaced. (one piece with the rocker cover, thanks VW!)
    Maf sensor has been cleaned.
    Fuel filter ha been replaced.
    Terrible fuel consumption.
    DPF light often comes on with continued highway driving.
    Help!!
    Aug 2013
    Esperance
    White smoke, dpf light all point to blocked dpf filter, have your dpf oil and ash levels checked and clean or replace your diesel particle filter.
    Are you aware of the oil consumption issue with the biturbi engine ?
    Mt Cotton
    Try a forced Regeneration of the DPF stick it in 3rd gear and drive at 80kmh for around 20 km and see if it clears , if not get a dealer or someone else to use the computer to do a forced regen .
    Dec 2016
    Shellharbour NSW
    Yea I have done that a couple of times when the dpf light comes on the dash. Thanks for the suggestion though.
    Dec 2016
    Shellharbour NSW
    Quote Originally Posted by Kombi View Post
    Dpf oil? How would the dpf effect the bad fuel consumption though?
    What particular biturbo oil problem?
    Thanks for the suggestion.
    Sunshine Coast
    When they tested the injectors did they run a compression test on the cylinders?, White smoke is un-burnt fuel.
    Dec 2016
    Shellharbour NSW
    Quote Originally Posted by H8T0W8 View Post
    A compression test had been done while the engine was cold. Showed good compression.
    I thought it could be related to the timing, ie too advanced or retarded, but it only happens once it’s warmed up.
    Aug 2013
    Esperance
    Soot can be cleaned through regeneration, but already burned soot, ash, cannot be cleaned through regeneration
    Aug 2013
    Esperance
    Limp mode happens when regeneration not possible
    Aug 2013
    Esperance
    Plenty biturbos suffer high oil consumption, egr cooler disintegration mostly blamed, but also valve stem seals and stuck oil rings
