Results 1 to 10 of 15
Thread: wheels and tyres
    Nov 2012
    wheels and tyres
    I currently run 16 in wheels with 215/65 tyres on my 2006 4motion.
    I have seen some stock 17 steelies from a 2013 van with 235/55 tyres.
    Will these go straight onto my 2006?
    this is probably a silly question, do I need a 17" spare with the same tyre profile or can I use the 16" I have?
    Thanks BR
    Feb 2008
    Adelaide,Oz
    note also that there isn't a great selection of load rated 17" tyres if you go this route.See the 17" tyre thread.
    Steve
    04 T5
    Adelaide hills, SA
    I have 2005 4Motion it came with the 17" steels and I wish it came on 16" wheels. The 17" tyres with the correct load rating are expensive and they don't last as the 16" tyres.
    The 17" wheels will fit straight to your 2006 4Motion.
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Rebuild View Post
    This is something that many do not even check. Not only do you have to match the rim size and tyre width and profile, you must also have at least the same load index or rating. This applies to ALL vehicles and not just commercial type vehicles.
    Pacific Paradise QLD
    Quote Originally Posted by wai View Post
    Plus you may not exceed the largest stock wheel and tyre diameter by more than 25mm
    Adelaide hills, SA
    The 16" and the 17" are factory fit for the T5 4motion. The 17" is 235/55/17 with the minimum 103load rating. There aren't many options with 103 and higher load rating. I'm sure that the OP is aware which size he needs.
    Nov 2012
    thanks guys, will be sticking with the 16's
    Mt Cotton
    Need some new tyres I have a full set off our new T5 only done 500kays
    Quote Originally Posted by BobRonk View Post
    Jun 2012
    Moorabbin, Victoria
    Cool new tyres
    I'm currently running Dunlop Sport 01 in 235/55/17 with the 103 load rating, and Ive travelled a little over 32k Km. They're already at the wear indicators front & rear.
    I know the VW's seem to be heavier on tyres, but is 32000km normal for anyone? Im in a heavily loaded van, so its not like I'm pulling doughnuts.
    Anyway, im in need for new tyres.
    What have you used for a commercial van?
    What do you like?
    My tyre man suggests the continental ($280ea) or nankang ($180ea). What are your thoughts?
    Feb 2008
    Adelaide,Oz
    search the 17" tyre thread.
    I don't regard Hankooks very highly
    Steve
    04 T5
