The Wheelchair Accessible Campervan
Well,
I Finally got around to starting my Wheelchair Campervan build, I've had a few delays along the way, most of them not due to me.
I finally received my new 2017 3200kg GVM midroof LWB Mid February and booked it into get the side loading lift only to find out that the lift wasn't ordered, even though i gave notice and put down my deposit, so i had a 11 week wait until it arrived from Germany
So apart from a few drives, it's been sitting in the basement until the lift was installed.
Had the Swivel seats installed as well as an E-Brake, while it was in the engineers, so i could remove the handbrake to allow the seat to swivel with the handbrake on.
The RIB bed was installed, ages ago, haven't slept on it yet, but it seems comfy and we picked a up a couple of Duvalays with memory foam to a better sleep, still airing out these and the RIB bed as the VOC are still a bit harsh.
So on the weekend i started to sound deaden and insulate the van, i am going a different way to how some people insulate, but i feel it will work and I've seen it done overseas, so I've got no issues with it.
I am using Resomat sound deadener, its an Australian made sound deadener, and it doesn't have butyl or bitumen as the deadening compound, it its a lot easier to install than Dynamat, and doesn't stink as at all.. I've used dynamite before, and i could never get rid of the smell, so i looked for different options for a camper van.
I also used a 10mm closed cell self adhesive foam with a aluminium reflective foil layer that i got from Hong Kong, and then 50mm reflective aluminium tape to cover all joints and to seal the foam against the edges.
The guessing game is to see if the self adhesive foam holds, as normally i would just spray contact adhesive and bond it to the van. time will tell.
Before applying the sound deadener, Closed Foam and tape, i cleaned the areas with isopropyl.
Anyhow, here is a few pics of the sound deadener and closed foam.
Resomat
Close Cell foam and taped
Resomat (i did roll the air bubbles out)
Close Cell Foam and Taped
Still have the Sliding Door, Tail Gate and Rear Panels to do this week, but at least I've finally started
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
