Results 1 to 5 of 5
Thread: Weight Distribution Hitch or Not
    Aug 2013
    Redcliffe WA
    Hi Guys, First post. I have a 2006 lwb T5 Crewvan 1.9 TDI. Can I use a WDH towing my camper/caravan which has a ball weight of 100kg? hanks, Rob
    Pacific Paradise QLD
    Quote Originally Posted by Robjohns2424 View Post
    You would only need a light one for 100kg
    The shepherds crook one would be enough. What does the cars manual say Usually if not allowed says so
    Apr 2012
    Berridale
    Hi RobJohns,
    The Transporters have a max tow ball weight allowance of 100kg. In Europe they have tight laws on tow ball weights and most European caravans are designed around this. If your caravan/camper is relatively light weight, the tow ball weight may be no more than 100kg, so should be fine without a WDH. Just make sure you pack your caravan evenly and don't load up your draw bars with heavy items such as gas bottles or bikes etc. The most important thing IMO is to have your caravan level, therefore you may need riser bars for your tow ball. Hope this helps.
    I use a WDH for my camper on mine. The main advantage is keeping the car level and ensuring you can get good drive with the front wheels. Only use a light one (Sheperds Crook) type.
    As WanbyMc mentioned I make sure I pack the camper evenly not exceed the ball weight. I measure my ball weight with kitchen scales before I go on a trip and take photos on my phone so I can remember how to repack it.
    From what I remember reading a long time ago a WDH does not decrease or increase your ball load.
    2012 Caddy Maxi Life
    2011 Multivan
    2008 Skoda Scout (Gone.......L)
    Quote Originally Posted by Skoda VW View Post
    You are correct the ballweight is always just that no matter how tight you pull a WDH.
    It does however lighten the weight on the rear by distributing some to the front wheels and the trailer wheels.
    The ball weight is still the same as its actually weighed when DISCONNECTED from the tow vehicle.
    Have had endless discussions on this when vanning as I had a van with a 300KG ballweight and an all up weight of 3 tonne
    With a unitized body it doesn't pay to have too heavy a one as it can cause body distortion.
