Results 1 to 10 of 13
Thread: Webasco Thermo Top C
    Nov 2007
    QLD
    I have a 2006 kombi beach and crawling underneath I see that it has a device underneath the passengers side which according to a label on the passengers door frame is a Webasco Thermo Top C, 12V/26W 5kw, diesel PME
    There is no controls for this on the dash and nothing in the manuals, so I have never used it.
    I am kind of hoping it is a campervan night heater, but preliminary investigation reveals that it might be a radiator water heater, not much use in QLD.
    Does anyone know what it is, what it is does, and how can it be used.
    Thanks
    Brian
    Jun 2007
    Quote Originally Posted by BrianJ View Post
    Thanks
    Brian
    Looks like it's an interior heater, integrates with the vehicle heater, the name is Webasto rather than Webasco. The link below should help.
    Webasto:Â*RV heating solutions: Thermo Top C
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Nov 2007
    QLD
    Quote Originally Posted by VW Convert View Post
    George
    That seems to be the model, but I have no controls on the dash or anywhere that I have ever seen. Maybe the device is there but the control circuitry was never installed. Why would VW do that though!
    Brian
    Mt Cotton
    If you ring Webasto products Australia in Sydney 02 85364800 I am sure they will be able to give you some dealer names in Qld for these products I sell and distribute the Webasto Sunroofs but do not get involved with the Thermo products .
    Nov 2007
    QLD
    Thanks for the info, I might do that.
    Brian
    Jul 2007
    Brian,
    Look at the centre console, left of the gear selector. There are two rotary dials that control the temp and fan for the Webasto.
    It is a diesel powered heater with outlets on the right hand side of the rear quarter panel. You can see the vents in the factory trim if you look closely.
    Webasco Thermo Top C-p1020444-jpg
    Nov 2007
    QLD
    I have never used those, as I thought they were only working from the normal engine heat, so you learn something everyday, I will now have to try this out. In my camping configuration the rear panel vents are somewhat blocked, but I can move the stuff I store there if the heater is used.
    Imagine having the van for seven years and only finding this out now !!!
    Brian
    Adelaide hills, SA
    Brian
    By a mistake, perhaps.
    A customer of mine received the flappy paddles under the steering wheel in his very base model Tiguan TDI with the DSG. There were never available even as an option in that Tiguan, they were not activated, they're just fitted.
    Nov 2007
    QLD
    To multiplexman;
    I have turned on the switches and heat control which only work when the ignition is on and the fans start up in the heat exchanger in the rear but if the engine is cold then only cold air comes out. I left it running for about 10min then got under the car and felt the exhaust of the webasto and it was cold so nothing is happening there.
    I then rang the expert at webasto in Sydney and he said that it may be only configured to heat the engine water for Europe, but he can't tell without the coolant plumbing diagram and wiring control circuits which i don't have. I have now read the manuals and found this device in the book and it says that it can heat the van cabin, but it may be only talking about how it is configured in multivans with full climate control, its hard to tell with such a poor manual.
    My next course of action I think will be to ring VW themselves to try to talk to someone who may know how this was configured in the beach model, its a long shot but its all I can think of. It seems strange to me that there is probably near to no owners in Australia who have used this heater or even know about it, considering it is quite a useful and expensive device.
    I will keep you posted, and if anyone has any ideas about this please post.
    Brian
    Jul 2007
    Hi Brian,
    Mine definitely worked with the engine off. That is the whole point of the Webasto unit. It preheats the engine coolant. This is more efficient than idling the engine. Once at temperature, the fans can circulate warm/hot air.
    I remember using it at Rutherglen one winter when it dropped below zero during the night. One of the very rare occassions...
