I am going from dim, distant memory...
I remember once mistakenly turning the Webasto controls instead of the aircon controls. I could not work out where the fan noise was coming from after I had parked.![]()
I'd agree that turning the fan from OFF should switch the unit on.
If ambient is 30 deg C, I reckon the Webasto may not switch on. I cannot remember if the Webasto can be configured for a high temp limit.
You can test with the van stone cold in the evening. Step inside, turn the key to Acc (not sure if this was required), and wait...
There was a Webasto technical insert with my Kombi Beach manual. It has gone with the van.
