Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: water decarbonization
    Apr 2017
    belgrave victoria
    It depends, you might have less than 1/2 tank when the DPF light comes on or if you use it as prevention just wait until you have less than 1/2 the tank. Alternatively you can use LM DPF Anti-clog it's good for 70L of diesel.
    Sent from my SM-N950F using Tapatalk
    Thank you Transporter just what i need to keep the dpf on the straight and narrow
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Aug 2013
    Esperance
    No shortage of anti flush enthusiasts online, a polarising practice it seems.
    Adelaide hills, SA
    Quote Originally Posted by Kombi View Post
    Thanks T, I’ll try Detox, I’ve never had a car with such smelly engine oil, do you have best practice recommendation for flush ! I service every 10000km but also burning 2L1000km. Are VW filters better then parts shops ?
    The oil consumption of 2L in 10,000km isn’t too bad. I’d start with 0.75L of LM Viscostabil added to oil at every oil change. I change oil in all our cars every 6months and no one had to add any oil between the oil changes, though they’d do less than 8,000km in that time.
    I don’t buy every filter from the dealer, but almost alway use recognised brand like Pureflux, Mann, Mahle, Knecht, Hengst from a reputable supplier. Also, I don’t consider VW genuine filter Filtron (Wix filters) brand as a good filter for my own cars, which you can get many times when buying from the dealer. IMO, they are inferior quality just looking at them and comparing to other filters and suddenly even Ryco air filter looks better with better paper and more pleats compared to Wix sorry to VW genuine Filtron.
    My favourite engine oil filter for 2.5TDI is Pureflux from the dealer, the same filter is in 2.0TDI CBAB in Golfs, Tiguan Octavias up to 2010.
    Erskineville, NSW
    as for walking can you recommend a good fat burning product ��
    In Jan 2016 I started walking 2km each way to/from train station (new job in CBD with no parking) in addition to what was a reasonably active lifestyle. I weighed 92kg. By Sep 2017 I weighed 74kg. I did modify my eating habits slightly but didn't "diet". I'm around 89kg now but that's because my walk to the station is only 200m and I stuffed my knee on a slippery floor. Getting back into it soon. It's hard work but not carrying those extra kilos are a lot easier on the joints. I'm mid-50s and the metabolism certainly slows down post-50yrs
    Mahle and Mann are both OEM suppliers to VW and are excellent filters that are available outside the VW spares network.
    Aug 2013
    Esperance
    Transporter it’s 2L per one thousand kilometres ��
    Are these brand name filters available from the likes of Repco etc ?
    Brad I walk 6km four times a week with my wife, better for the waste than dinner dates !
    Adelaide hills, SA
    That’s bad then..
    No, they’re from HSY.
    Aug 2013
    Esperance
    Thank you T, never knew about HSY, definitely getting a couple Mahle filters next week in Perth.
    T do you judge engine flush as risky, even if done correctly, iow 5-10 minute idle and oil and filter change immediately after ?
    Adelaide hills, SA
    Engine oil flush is safe as long as you use right product. The Penrite engine flush is very safe, even recommended as a cure for noisy lifters.
