Results 1 to 8 of 8
Thread: T5 ESSENTIALS (from September 2009), Fuses location,
    Adelaide hills, SA
    It’s been discussed in our forum that the latest T5 has no fuse box assignment notes in the owner’s manual or on the fuse boxes covers. Here is some info for now (more will come later), I’d like, if someone could take the pictures of their fuse boxes so we could have some “real life” examples.
    Please use this thread for comments. http://www.vwwatercooled.org.au/foru...dex-64025.html
    Code:
    Fuses location and meaning
    No. Current Flow Diagram designation/Nominal Function/component/Terminal value (not a real value unless you have the wiring diagram, so I removed the information from the content)
    1-Fuse 1 on fuse holder F - 15 A
    2-Fuse 2 on fuse holder F - 3 A
    3-Fuse 3 on fuse holder F - 15 A
    4-Fuse 4 on fuse holder F - 15 A
    5-Fuse 5 on fuse holder F - 5 A
    6-Fuse 6 on fuse holder F - 25 A
    7-Fuse 7 on fuse holder F - 30 A -12 V socket
    8-Fuse 8 on fuse holder F - 25 A- Heater control unit, remote control receiver for auxiliary heating
    9-Fuse 9 on fuse holder F - 25 A- Fresh air blower isolation relay, Voice amplification control unit Rear blower regulation motor
    10-Fuse 10 on fuse holder F -3 A or 15 A-Auxiliary heater relay
    11-Fuse 11 on fuse holder F -15 A -Cigarette lighter
    12-Fuse 12 on fuse holder F -15 A
    13-Fuse 13 on fuse holder F -SF13- -Vacant
    14-Fuse 14 on fuse holder F -SF14- -Vacant
    15-Fuse 15 on fuse holder F -SF15- -Vacant
    16-Fuse 16 on fuse holder F -SF16- -Vacant
    17-Fuse 17 on fuse holder F -SF17- -Vacant
    18-Fuse 18 on fuse holder F -SF18- -Vacant
    19-Fuse 19 on fuse holder F -SF19- -Vacant
    20-Fuse 20 on fuse holder F -SF20- -Vacant
    21-Fuse 21 on fuse holder F -SF21- -Vacant
    22-Fuse 22 on fuse holder F - 15 A-12 V socket 2
    23-Fuse 23 on fuse holder F - 15 A-12 V socket 3
    24-Fuse 24 on fuse holder F - 10 A 15A only models with auxiliary coolant heater
    25-Fuse 25 on fuse holder F - 15 A-Trailer detector control unit -J345-30
    26-Fuse 26 on fuse holder F - 20 A-Trailer detector control unit -J345-30
    27-Fuse 27 on fuse holder F - 20 A-Trailer detector control unit -J345-30
    28-Fuse 28 on fuse holder F – 7.5 A-Reversing camera system control unit -J772-30a
    29-Fuse 29 on fuse holder F -SF29- -Vacant
    30-Fuse 30 on fuse holder F - 5 A-Voice amplification control unit -J656-30
    31-Fuse 31 on fuse holder F -SF31- -Vacant
    32-Fuse 32 on fuse holder F -SF32- -Vacant
    33-Fuse 33 on fuse holder F - 15 A-Driver seat lumbar support adjustment 30 switch
    34-Fuse 34 on fuse holder F - 40 A - Right sliding door control unit -J731-
    35-Fuse 35 on fuse holder F - 80 A-Battery isolation relay -J7-30
    36-Fuse 36 on fuse holder F -SF36-40 A-17-pin connector
    Adelaide hills, SA
    FUSE HOLDER "D"
    Code:
    No. Current Flow Diagram designation/Nominal/Function/component/Terminal value
    1-	Fuse  -5 A- Radiator fan control unit -J293-87
    2-	Fuse  -5 A- Additional coolant pump relay -J496-30
    3-	Fuse  -5 A- Heater element for crankcase breather -N79-15
    4-	Fuse  --Vacant--
    5-	Fuse  -15 A- Mechatronic unit for dual clutch gearbox -30 J743- Selector lever lock solenoid -N110- Selector lever
    6-	Fuse  6  -30 A- ABS control unit -J104-30
    7-	Fuse  --Vacant--
    8-	Fuse  --Vacant--
    9-	Fuse  -5 A- Engine control unit -J623-30
    10-	Fuse  -5 A- Secondary air pump relay -J299- 87. Fuse 15 A 3)- Charge pressure control solenoid valve -N75- - Activated charcoal filter system solenoid - valve 1 -N80- -Exhaust gas recirculation cooler change-over valve -N345- Charge pressure control solenoid valve 2 -N274-
    11-	Fuse  30 A-Headlight main beam relay -J12—
    12-	Fuse  10 A- Fuel metering valve -N290- 15 -Fuel pressure regulating valve -N276-or 87
    13-	Fuse  -10 A-Left gas discharge light control unit -J343-15
    14-	Fuse  -5 A- Fuel pump relay -J17- 15- Relay for supplementary fuel pump -J832- -Clutch pedal switch -F36-
    15-	Fuse  -10 A- Reversing light switch -F4-15
    16-	Fuse  -5 A- Air mass meter -G70- 15 Brake light switch -F-17-
    17-	Fuse  -5 A- TCS and ESP button -E256- 15-ABS control unit -J104-
    18-	Fuse  -5 A- Power steering control unit -J500—
    19-	Fuse  -5 A- Clutch pedal switch -F36- 15-Air mass meter -G70-1)
    20-	Fuse  -5 A-Engine control unit -J623-15
    21-	Fuse  -5 A-Exhaust gas recirculation valve -N18-87
    22-	Fuse  -10 A- Injector, cylinder 1 -N30- 87a- Injector, cylinder 2 -N31- - Injector, cylinder 3 -N32- -Injector, cylinder 4 -N33-
    23-	Fuse  -10 A-Right gas discharge light control unit -J344-15
    24-	Fuse  -5 A-Mechatronic unit for dual clutch gearbox -15 J743- Selector lever -E313-
    25-	Fuse  -30 A- Engine control unit -J623- 87-Ignition transformer -N152-
    26-	Fuse  -5 A- Left day driving light bulb -L174-87
    27-	Fuse  -10 A-Continued coolant circulation pump -V51-87
    28-	Fuse  -15 A-Treble tone horn -H2-4) 30
    29-	Fuse  -5 A-Right day driving light bulb -L175-87
    30-	Fuse -20 A- Fuel system pressurisation pump -G6- 30 - Fuel pump relay -J17- -Relay for supplementary fuel pump -J832-
    31-	Fuse  -15 A-Lambda probe heater -Z19- Lambda probe 1 heater after catalytic converter -Z29-2)
    32-	Fuse  -30 A- 3) -Engine control unit -J623- 5 AElectric fuel pump 2 relay -J49-2)
    33-	Fuse  -5 A- Additional coolant pump relay -J496-87
    34-	Fuse  -5 A-Onboard supply control unit -J519- (T73b/59)30
    35-	Fuse  --Vacant87
    36-	Fuse 36  -30 A-Additional coolant pump relay -J496-30
     Note 1) for engine codes CAAA, CAAB, CAAC, CCHA only 2) for engine code AXA only 3) only models with diesel engine 4) for models with taxi equipment only.
    Adelaide hills, SA
    Fuses in the fuse holder B and C
    Code:
     Fuse holder B and C
    Location:  In the lower fuse box on centre of dash panel
    Fuse colours
    40 A - blue
    30 A - green
    25 A - white
    20 A - yellow
    15 A - blue
    10 A - red
    7.5 A - brown
    5 A - beige
    FUSE HOLDER B
    No./Current Flow Diagram /designationNominal/Function/componentTerminal value
    1-Fuse  -30 A-Terminal 15 voltage supply relay -J329-30
    2-Fuse  -5 A-Steering angle sender -G85-30
    3-Fuse  -10 A-Onboard supply control unit -J519- 30 (T73b/39)
    4-Fuse  -5 A- W8 Connection (15a), in rear wiring harness 15a- Lane change assist control unit 2 -J770- -       Lane change assist control unit -J769-
    5-Fuse  -15 A- Left headlight twin filament bulb -L1-56b
    6-Fuse -15 A- Left headlight twin filament bulb -L1-56a-
    7-Fuse  -15 A-Onboard supply control unit -J519- (T73a/66) 1)
    8-Fuse  -15 A-Rear lid control unit -J605-30    -20 A- Alarm horn -H12- 30- Onboard supply control unit -J519- (T73/16) - Left sliding door control unit -J558- - Rear lid control unit -J605- -Right sliding door control unit -J731-
    9-Fuse  -30A-Onboard supply control unit -J519-30
    10-Fuse -10 A- Intermittent wiper switch -E22- 15- Rear wiper switch -E34- -Intermittent wiper regulator -E38-
    11-Fuse  -5 A-Number plate light -X-58
    12-Fuse  -5 A -Light switch -E1-30 30 A
    13-Fuse  -7,5 A-Airbag control unit -J234-15
    14-Fuse  -25 A-Steering column electronics control unit -30 J527-
    15-Fuse  -7,5 A-Fresh air blower switch -E9-75
    16-Fuse  -5 A-Onboard supply control unit -J519- 15 (T73a/44)
    17-Fuse  -5 A- Rear fog light warning lamp -K13- RFL-Rear left fog light bulb -L46-
    18-Fuse  -5 A-Control unit in dash panel insert -J285-30
    19-Fuse  -5 A-Ignition/starter switch -D-86s
    20-Fuse  -5 A-Diagnostic connection -U31-30
    21-Fuse  -10 A- Starter motor relay -J53- 50-Engine control unit -J623-
    22-Fuse  -7,5 A- Control unit in dash panel insert -J285- 15-Diagnostic connection -U31- (T16/1)
    23-Fuse  -30 A - Ignition/starter switch -D- 50 5 A-Onboard supply control unit -J519- (T73b/50)
    24-Fuse  -5 A-Steering angle sender -G85-15
    25-Fuse  -7,5 A-Fresh air blower switch -E9-30
    26-Fuse  -30 A-Light switch -E1-75x
    27-Fuse  -15 A- Right headlight twin filament bulb -L2- 56b- B456 Connection (56b), in main wiring –harness
    28-Fuse  -15 A- Right headlight twin filament bulb -L2- 56a- B142 Positive connection 2 (56a), in interior - wiring harness -Control unit in dash panel insert -J285- (T32/14)
    29-Fuse  -10 A-Dual signal inverter relay -J741-30a
    30-Fuse  -10 A- Left washer jet heater element -Z20- 75- Right washer jet heater element -Z21- - Rear window wiper motor -V12- - Rear right wing door window wiper motor --V93- Rear left wing door window wiper motor -V92-
    31-Fuse  -30 A-Onboard supply control unit -J519- 30 (T73a/73)
    32-Fuse  -30 A-Onboard supply control unit -J519- 30 (T73a/68 )
    33-Fuse  -30 A- Radio -R- 30 Control unit with display for radio and navigation system -J503-
    34-Fuse  -25 A- X-contact relief relay -J59- 15- Fuse 14 on fuse holder D -SD14- -Fuse 20 on fuse holder D -SD20-
    35-Fuse  -5 A- B340 Connection 1 (58d), in main wiring 58d- harness -B341 Connection 2 (58d), in main wiring harness B342 Connection 3 (58d), in main wiring harness
    36-Fuse  -25 A-Onboard supply control unit -J519- 30 (T73b/13)
    Note 1) for models with roof console only
    Fuse holder C
    No./Current Flow Diagram designation/Nominal Function/component/Terminal value
    1-Fuse  -15 A- Trailer detector control unit -J345- 15a -10-pin connector -T10bh/1-75a
    2-Fuse  -5 A- Interior monitor send and receive module 2 -30-G305- Anti-theft and tilt system control unit -J529-
    3-Fuse  -10 A - Red Cross light switch -E10- 30 15 A-Red Cross light warning lamp -K100-
    4-Fuse  -10 A- Differential lock control unit -J187- 15a- Rear differential lock switch -E121- -Four-wheel drive control unit -J492-5-Fuse 5 on fuse holder C -SC5-10A-6-pin connector -T6bn/5-75x
    6-Fuse  -5 A-Oil level and oil temperature sender -G266-15
    7-Fuse  -30 A -Rotating light switch -E162- 30 10 A
    8-Fuse  -5 A-Parking aid control unit -J446-30
    9-Fuse  -5 A-Steering column electronics control unit -30 J527- Adaptive cruise control unit -J428-
    10-Fuse  -10 A - Left headlight range control motor -V48- 15 5 A-Right headlight range control motor -V49- Switches and instruments illumination regulator -E20-
    11-Fuse  -15 A-Left sliding door control unit -J558-58
    12-Fuse  -5 A -Left day driving light bulb -L174-30 30A
    13-Fuse  -5 A-Drive train CAN bus isolation relay -J788-15
    14-Fuse  -5 A -Right day driving light bulb -L175--30A
    15-Fuse  -5 A-Mobile telephone operating electronics 15-control unit -J412-
    16-Fuse  -7,5 A- Navigation system tuner for TV -J415- 30-Interface for external multimedia unit -R215-17-Fuse  -7,5 A- Onboard supply control unit -J519- (T73/66) 30 1) -1) 30G 2) Interior lights and compartment lights 2)
    18-Fuse  -5 A- Air conditioning system control unit -J301- 30- Rear fresh air blower switch -E179- - Operating and display unit for rear -Climatronic -E265- Rear blower regulation sender -G463-
    19-Fuse  -5 A-Automatic anti-dazzle interior mirror -Y7- 86s
    20-Fuse  -10 A-Onboard supply control unit -J519- 30 (T73a/64)
    21-Fuse  -5 A-Rain sensor -G213-RPL
    22-Fuse  -5 A- Air conditioning system pressure switch -15-F129- Air quality sensor -G238-
    23-Fuse  -10 A- Residual heat relay -J708- 30a- Remote control receiver for auxiliary coolant -heater -R149- Auxiliary heater operating and display unit -E407- Operating and display unit for camping equipment -E153-
    24-Fuse  -7,5 A- Left centre reading light -W39- 30G- Right centre reading light -W40- - Rear left reading light -W11- - Rear right reading light -W12- - Left interior light -W16-- Right interior light -W17- - Rear left interior light -W47- -Rear right interior light -W48-
    25-Fuse  -25 A-Seat heating control unit with regulator -J396-
    26-Fuse  -10 A-Tachograph -G24-30
    27-Fuse  -30 A- D51 Positive connection 1 (15), in engine 15 compartment wiring harness - Fuse 13 on fuse holder D -SD13- -Fuse 23 on fuse holder D -SD23-
    28-Fuse  -5 A- Mirror adjustment switch -E43- 15-Exterior mirror heater button -E231-
    29-Fuse  -25 A-Heater control unit -J162-30
    30-Fuse  -5 A- Operating and display unit for camping 75-equipment -E153- Auxiliary coolant heater relay -J493-
    31-Fuse  -25 A -Sliding sunroof adjustment control unit -30 5 AJ245-
    32-Fuse  -20 A-Headlight washer system relay -J39-15
    33-Fuse  -5 A-Tachograph -G24-15
    34-Fuse  -5 A-Vacant15
    35-Fuse  -20 A-Onboard supply control unit -J519- 30 (T73b/11)
    36-Fuse  -5 A-10-pin connector -T10bh/9-30
    Note 1) for models without roof console only 2) for models with roof console only.
    Adelaide hills, SA
    Fuse holder A
    Location In engine bay, Left front, Infront of the battery. Look at the picture in the post #1.
    Code:
    No. / Current Flow Diagram / designation Nominal Function / component Terminal value
    1 - Fuse  -175 A - Alternator -C-30 225 A-
    2 - Fuse  -125 A- X-contact relief relay -J59- 30- B298 Positive connection 2 (30), in - main wiring harness -B301 Positive connection 5 (30), in main wiring harness B302 Positive connection 6 (30), in main wiring harness B303 Positive connection 7 (30), in main wiring harness B304 Positive connection 8 (30), in main wiring harness B305 Positive connection 9 (30), in main wiring harness Fuse 9 on fuse holder B -SB9- Fuse 14 on fuse holder B -SB14-
    3 - Fuse  -50 A - Battery isolation relay -J7- 30 100 A- Second battery charging circuit relay -J713- B310 Positive connection 14 (30), in main wiring harness B311 Positive connection 15 (30), in main wiring harness
    4 - Fuse  -70 A-D50 Positive connection (30), in engine 30 compartment wiring harness
    5 - Fuse  -50 A- ABS control unit fuse 1 -S123- 30-Fuse 6 on fuse holder D -SD6-
    6 - Fuse  -60 A - Automatic glow period control unit -30 50 A-J179- Secondary air pump relay -J299-
    7 - Fuse  -100 A-Radiator fan control unit -J293-30
    8 - Fuse  -40 A - B169 Positive connection 1 (30), in 30 50 A interior wiring harness 100 A- B170 Positive connection 2 (30), in interior wiring harness - Fuse 9 on fuse holder F -SF9- - Fuse 14 on fuse holder F -SF14- - Fuse 22 on fuse holder F -SF22- - Fuse 23 on fuse holder F -SF23- -Fuse 24 on fuse holder F -SF24-
    9 - Fuse  -100 A- B272 Positive connection (30), in main 30- wiring harness B299 Positive connection 3 (30), in main wiring harness
    Adelaide hills, SA
    The Links To Useful & Handy Threads
    Adelaide hills, SA
    Soundproofing the T5 interior.
    New T5 Project
    Thanks and thumb up to Sunny43.5
    Adelaide hills, SA
    Adelaide hills, SA
