Best way I found to fit an oversize tyre is to make sure the rear support strap is on the lowest hole and then put the wheel into place and jack the very end of the rear part until you can start the bolt after that its a breeze .
Thanks to Murphenzo and Sunny43.5 for the inspiration to stuff this oversize spare into its spot. Two and a half hours it took me, I eventually jacked the van up and then lowered it onto blocks of wood to squeeze the spare up into the well. It was not easy at all and I am not going to do that out in the scrub anywhere. Frontline in Sydney have a method to "modify" the tray to accommodate an oversize tyre, we are having a diesel heater fitted there next month, so I hopefully I can get them to modify ours. The other alternative would be a Seikel oversize tyre tray, but at 450 Euro plus delivery I reckon that's a bit much.
Is it the diameter that's the issue or the width ?
Is there any rear wheel carrier to fit on the Transporters?
Perhaps with the towing hitch combo.
I am not sure how to link to another thread on this forum so I just copied the title....
Tailgate Tyre/Jerrycan carrier.
If that doesn't work then here is the URL to a place that has made one for a T5, cant remember where I saw it though.
I did not want to go that way to try and keep the weight down..not to mention the dollars.
Thank you Rtee
Reviving an old thread. Out of interest any update on how frontline modify the spare wheel carrier?
Also keen to know about what frontline do.
Attempting to get a 245/65/17 in my spare wheel carrier as a matching spare for my amarok wheels.
Will try deflating it first as others have had success with but it seems miles off at the moment.
Also think the I need to get my hands on the longer carrier bolt if anyone knows where to get a part number.
