Results 1 to 9 of 9
Thread: VW T5 2011 4motion, which oil and filter
    May 2016
    Gladstone
    Hey hey,
    Im about to do an oil filter and oil change myself,
    2011 T5 4 CFCA Motor 2.0L twin turbo 4motion
    Just wondering what oil everyone is using?
    Is Penrite Enviro+ C3 5-30w okay to use?
    And
    Ryco Z435 for the oil filter.
    All purchased from Repco...causVW want to charge $489 just for oil and oil filter change
    Jul 2016
    i think it's 507.00 spec oil you need, super cheap just had a special on Castrol 507.00
    I think you also need a a one use crush washer for the oil plug.
    Im still in warranty, so i haven't bothered to change my own oil.
    One of the lads on here will confirm if im correct
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Arrawarra
    Probably avoid the ryco & fork out for a genuine or a Mann filter I reckon.
    Aug 2019
    Southport Qld
    This is the oil used from Repco .Used Ryco Z435. First oil change on this type of VW. Straight forward. Did not use crush washer , but normally do. Just get a few next time. No leaks. Used about 7 litres of oil .
    Sunshine Coast
    I'd recommend Mobil 1 ESP 5w30 and as someone else said only genuine filters.
    Sent from my SM-N960F using Tapatalk
    Aug 2013
    Esperance
    Need VW spec 507.01
    I’ve used Penrite and Castrol, around $10L on specials, Mahle and Man filters from hsy, your engine using oil ?
    Adelaide hills, SA
    Quote Originally Posted by Sendo_VW_multivan_2010 View Post
    The Z435 is definitely wrong filter. As other suggested use genuine filter only and I’d be voiding eBay filters since they’re unknown quality. The risk is just not worth it.
    Aug 2013
    Esperance
    Hi Transporter, without dpf is specific oil still as crucial for engine and turbo ?
    Adelaide hills, SA
    Quote Originally Posted by Kombi View Post
    It is, even for 2.0TDI. In case of 2.5TDI AXD and AXE engines, don’t even think about using anything than approved 506.01 oil.
