Page 25 of 27 FirstFirst ... 152324252627 LastLast
Results 241 to 250 of 263
Thread: VW T5.1 excessive oil use
  1. #241
    Aug 2013
    Esperance
    I got goodwill and I am the second owner, car has full dealer service history.
  2. #242
    May 2016
    Gladstone
    No Logicpr0be! Moral is to not buy a 2011 VW Transporter with the wrong suffixed egr cooler. More info can be looked for using the facebook page
    VW T5.1 / T6 EXCESSIVE OIL USE FOR CFCA 2.0....
    Sounds like theres a few of us 2nd hand buyers who are getting this fixed OUT OF WARRANTY and under goodwill! This is great news...please write in this post if you have had similar success and how you went about it...cause it is so stressful finding a way around the issue!!
  3. #243
    Aug 2016
    NSW
    I've still got my old one.................I'm gonna check the number!
    2018 Crafter Runner
    T5.1 6sp manual.
  4. #244
    Aug 2013
    Esperance
    Simply did oil consumption test through dealer, a engine compression test, replaced a leaking rocker cover gasket, tpi concluded engine replacement, asked dealer to request goodwill from vw, result vw covering parts and I the labor
  5. #245
    May 2016
    Gladstone
    Facebook group, here you will find details on how to determine if you have the EGR COOLER which corrodes and destroys piston rings and allows the high oil consumption
    VW T5.1 / T6 excessive oil use for CFCA 2.0 180hp engines. public group | Facebook
  6. #246
    Aug 2016
    NSW
    Mine's a single turbo..........I'm guessing they use a different one.
    2018 Crafter Runner
    T5.1 6sp manual.
  7. #247
    May 2016
    Gladstone
    I hope so mate! Is it a CFCA motor?
  8. #248
    Jan 2018
    Castlmaine
    Hi it is great to read your post.
    I had oil issues from when I bought my T5 transporter x nsw ambulance at 55,000km. Took two years of being mucked about by Poysner Motors Bendigo and thousands of dollars despite them mentioning on day one that they had an internal memo for this very issue.
    I finally tried another dealer, VW ballart in Victoria who were fantastic. VW paid for new engine and labour.
    However VW Bendigo were so bad I’m taking them to VCAT in 3 July 2019 to get the $5500 that they wasted back. (That’s just for one service at 100,000 which they said would help! not including other costs, trips and time spent!)
    There are VW internal memos for this issue TPI which I have the number of at home. It’s specifically for t5 I’m trying to find a copy for the VCAT hearing and any other stories that validate it from forums etc. So that there is evidence that the judge knows this is a known issue and faulty vehicle!!!
    If anyone has info ASAP it would be appreciated
  9. #249
    Mar 2019
    Castle Hill, NSW
    Hi Laney695, check this one out https://f01.justanswer.com/350matt/1...onsumption.pdf
    is this the TPI?
    does anyone here know how to identify faulty engine just by engine code/VIN?
  10. #250
    Sunshine Coast
    Your engine number should be on your registration paper work.
    Sent from my SM-N960F using Tapatalk
