Page 18 of 27 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 263
Thread: VW T5.1 excessive oil use
  1. #171
    Aug 2013
    Esperance
    Where do you guys get the oil test done ?
    Taking my car to Perth for assessment on Tuesday
  2. #172
    Jul 2016
    Quote Originally Posted by Kombi View Post
    I've been using e-Monitor oil analysis - A blood test for your vehicle - Australian Laboratory Services - Australia
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
  3. #173
    Aug 2013
    Esperance
    Aug 2017
    Holsworthy, NSW
    My oil test was purchased via nulon website, then everything done via post
  5. #175
    Feb 2009
    NSW
    How do I get to the intercooler hose inlet? I want to see if there's any oil in there.
    Sent from my Pixel 2 using Tapatalk
  6. #176
    Aug 2013
    Esperance
    Dunno ozgti, but I spoke to a technician in Perth today and he said that is the first place he will look for oil,
    I had my car assess by vw dealer in Perth, now waiting for approval from car dealer whom I bought my ‘12 multi from, interesting the dealer made no mention of the common issue with these engines relating to the egr, they suggested fixing the small oil leaks at flywheel and check oil consumption thereafter,
    Trip from Esperance to Perth was exactly 800km and used 75l diesel and 1,8l oil, @ a very steady 110km/h, my previous 2,5 used roughly the same fuel, but no oil
    Hoping my statutory warranty will cover my expenses
    Btw hoddy, for what it’s worth, my 2,5 used to go into limp mode often first time you drive cold engine and you accelerate hard for first time, I replaced a$100 Bosch vacuum sensor and never had the issue or engine light come on again
  7. #177
    Aug 2013
    Esperance
    Just got a call from dealer seller that they are refusing my claim to have my car fixed under warranty! Any suggestions?
    Had my egr blanked off, both inlet and outlet side, will report if my oil consumption changes.
    - Oil consumption no different with egr blanked after 1K ��
  8. #178
    Feb 2009
    NSW
    Took it to wolfsburg motors while we are away. Diagnosis is most probably head gasket. Pressurised it for over an hour and went to start it. Started on 3 cylinders then ran fine. Egr looked ok and thinks the oil consumption is related.
  9. #179
    Aug 2013
    Esperance
    Hi ozgti, trying to figure your issue, you losing oil and coolant ?
  10. #180
    Feb 2009
    NSW
    Yes. 1 coolant tank per 100kms. Oil.. About 1l per tank.
