Where do you guys get the oil test done ?
Taking my car to Perth for assessment on Tuesday
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
My oil test was purchased via nulon website, then everything done via post
How do I get to the intercooler hose inlet? I want to see if there's any oil in there.
Sent from my Pixel 2 using Tapatalk
Dunno ozgti, but I spoke to a technician in Perth today and he said that is the first place he will look for oil,
I had my car assess by vw dealer in Perth, now waiting for approval from car dealer whom I bought my ‘12 multi from, interesting the dealer made no mention of the common issue with these engines relating to the egr, they suggested fixing the small oil leaks at flywheel and check oil consumption thereafter,
Trip from Esperance to Perth was exactly 800km and used 75l diesel and 1,8l oil, @ a very steady 110km/h, my previous 2,5 used roughly the same fuel, but no oil
Hoping my statutory warranty will cover my expenses
Btw hoddy, for what it’s worth, my 2,5 used to go into limp mode often first time you drive cold engine and you accelerate hard for first time, I replaced a$100 Bosch vacuum sensor and never had the issue or engine light come on again
Just got a call from dealer seller that they are refusing my claim to have my car fixed under warranty! Any suggestions?
Had my egr blanked off, both inlet and outlet side, will report if my oil consumption changes.
- Oil consumption no different with egr blanked after 1K
Took it to wolfsburg motors while we are away. Diagnosis is most probably head gasket. Pressurised it for over an hour and went to start it. Started on 3 cylinders then ran fine. Egr looked ok and thinks the oil consumption is related.
Hi ozgti, trying to figure your issue, you losing oil and coolant ?
Yes. 1 coolant tank per 100kms. Oil.. About 1l per tank.
