Page 13 of 27 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 263
Thread: VW T5.1 excessive oil use
  1. #121
    Dec 2008
    Sydney/Canberra
    You are right Umai another member Andrew 123 posted a link from Germany which gave full details , as I said if VW knew it was a fault they should repair or replace anyones van affected free of charge .
    New van? That's a bit excessive, when only the engine is faulty.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #122
    Aug 2016
    South Yarra
    Saltdog this is terrible news and I truly feel for ya. Have a good read on the T5-life forum as this issue is known and very common in the UK and Europe.
    The fault, as someone else has explained, lies in the EGR breaking down internally and letting small aluminium particles get into the combustion chamber and scoring the bores therefore allowing the engine oil to pass through and be burnt.
    Did you notice if the van was actually driving better at any point?
    I too have the same model van with a pre suffix EGR cooler and have taken the first steps of monitoring my oil by 1. changing it at 10,000kms intervals and 2. testing the oil at 5,000kms intervals.
    First oil test so far has shown unusual signs of wear but it's only the first test on 10,000km old oil at 139,000kms. Next test is due in about 2,500kms without an oil change then again at 150,000kms to establish a wear trend.
    I also had a compression test done at approx 135,00kms with the results all being in the normal range.
  3. #123
    Mt Cotton
    Quote Originally Posted by Umai Naa!! View Post
    Well I did mean the engine !
  4. #124
    Dec 2016
    What are the options if this proactive testing finds something?
  5. #125
    Jul 2016
    Quote Originally Posted by jonathan_k View Post
    In Markee's case, if there is an extremely high Aluminium reading at the 5000km mark via testing, he can change the oil knowing that the next 5000km he isn't damaging the bores as much by not knowing the aluminium is scoring the bores.
    Mine, is merely a safe guard to see what is happening to my engine as its new, and if this issue comes up, i have some data if i have to get goodwill from VW.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
  6. #126
    Aug 2016
    South Yarra
    Yup what Bryn said and I'll also be 'mapping' out/blocking the EGR and removing the DPF for good measure
  7. #127
    Feb 2009
    NSW
    I have this now. 2011 TDI400 4 motion. Using roughly 1l of oil per 500kms. And losing coolant too... Fml. I hope the 2nd hand car warranty covers this...
    Sent from my SM-G930F using Tapatalk
  8. #128
    Adelaide hills, SA
    Quote Originally Posted by ozgti View Post
    How many km on engine?
  9. #129
    Feb 2009
    NSW
    171687
  10. #130
    Jul 2016
    ****ty news just before xmas, hopefully you are covered under the 2nd car warranty.
