Page 23 of 27 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 263
Thread: VW T5.1 excessive oil use
  1. #221
    Sep 2012
    Narrabeen, NSW
    I have owned it since new and had it serviced at VW approved places on schedule.
  2. #222
    Feb 2009
    NSW
    Sgs parts at thornleigh have them, about 8k, 1k fitted.
    Mine had a cracked head... But it was behind a valve.)
    Sent from my Pixel 2 using Tapatalk
  3. #223
    Adelaide hills, SA
    Quote Originally Posted by orcasouth View Post
    To be the original owner always helps, though the time and kms are not in your favour. Let us know on the progress.
  4. #224
    Aug 2016
    NSW
    I would expect a long motor for $11.5k!
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
  5. #225
    Jul 2016
    I just had my oil results come back today after the second service at 13000km
    A high reading of Aluminium, 32 ppm with a caution note on the reading.
    I'll be looking at getting an oil consumption test soon, when i know ill be doing large highway km.
    I Still have a year left of my warranty
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
  6. #226
    Adelaide hills, SA
    Quote Originally Posted by Bryn23 View Post
    Yes, the Al particles are bit higher, but the engine is still running in. I’d change the engine oil every 6months during running in period and even after if you drive short trips or don’t travel often enough.
    What recommendation came on the report?
  7. #227
    Jul 2016
    I know the the engine is running in, but i just find it odd that its a lot higher than the last two oil tests
    1750km 16ppm
    5721km 20ppm
    13212km 32ppm
    And the oil was changed after each test.
    I looking at a lap of Aus in about 3 months, so that will definitely get some km on the engine before the warranty period is up.
    As for recommendations, resample at a reduced service interval to further monitor
    as VW did the oil changes, i don't have access to what came out of the sump.
  8. #228
    Adelaide hills, SA
    Here is UOA result from my 2005 T5 which had all aluminium engine Google Sheets: Mag-sign In
    T5 UOA.doc - Google Docs
    as you can see I’ve (done by me not the dealer) changed oil at 2600km and at 14,000km, the Al particle count dropped dramatically. It’s important that with every oil change you replace oil filter as well.
    Link to the rest of my old post. T5 FAQ and How to THREAD (up to August 2009).
    Can you post all 3 UOA results here? Maybe do the 4th one now, just after the oil change.
  9. #229
    Sep 2018
    Lakes Entrance Victoria
    I'd personally change it at 10,000km, just as i'll change the oil out after the first 1500km. its just something that i believe in, and oil is cheaper than an engine rebuild.
    I don't believe in long life oil, as it does appear to be thinner..
    I do agree with using the correct oil spec, i did notice, people using 507 oil instead of 504 oil were having cam wearing issues (if i can recall it right) as the 507 didn't have an additive.
    Whether it makes a difference in by changing the oil early at all, i don't really know if it would help in this instance.
    If it is a flaw in the engine design, oil change wouldn't have made a huge difference..
    The key is finding out what was done to the later engines to resolve this issue, as then under your AUS rights, you can proof it wasn't fit for use, hence the redesign.
    Hopefully you can get VWA to the table to pay for most of it... i wouldn't expect them to pay 100%, but getting of with 70% would help.
    Keep us informed, with your research..
    Check out Lemon Laws , things have changed in the favour of the purchaser of vehicles/ caravans etc.
  10. #230
    Sep 2018
    That's from 2004/2005 book and corrected later as far as I know.
    Many earlier T5s with 2.5 TDI used wrong oil specs and paid the price later. The Penrite back then had an oil with not approved specs HPR0 0W-30 (506.01) and also HPR Diesel5 5W-40, but soon stopped recommending it to be used where VW506.01 is required. The Castrol only supplier of approved VW506.01 was supplying only to VW dealers, in other words, you couldn't buy it, or order it even if you were retailer or workshop.
    Later, around 2009/10 you could get Fuchs/TITAN oil that was VW506.01 approved. Today there is also LIQUI MOLY with the right specs for before 7/2006 T5s AXD and AXE engines without DPF.
    Use anything else in these engines and they will not last!
    I have a 2010 crewcab 2.5 tdi single turbo, so what oil should I use.
