Page 10 of 27 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 263
Thread: VW T5.1 excessive oil use
  1. #91
    Feb 2009
    Torquay
    Ok, I've got a plan.
    2010 5.1 is leaking oil due to engine damage from EGR. Engine still runs well but comes up with fault codes / limp mode etc.
    First step - prevent further damage
    ----> gut the DPF, blank the EGR, remap ECU and maybe a performance tune for a bit of power.
    Second step - oil change maybe with a thicker oil to prevent excessive oil loss.
    Third step - maybe can live with oil loss as long as engine still ok. If engine gets worse then I'd need a new engine but would not need DPF or EGR replaced as these would have already been dealt with.
    Booked to have it done next Friday.
  2. #92
    Mt Cotton
    I spoke to a German mechanic the other day he specializes in VW AUdi BMW Mercs only , I broached him about EGR blanking DPF etc . He was very knowledgeable about possible problems that may occur down the track after around 20 to 30thou km after the mods are done . Apparently the EGR and its cooler is designed to keep the engine operating temp in a very defined range , without the EGR that will change and over time can lead to piston failure .
  3. #93
    Feb 2009
    Torquay
    I would have thought it would run cooler, which is a good thing for Australian climate. And s free flowing exhaust can only be a good thing as well.
    Given the engine I've got already has cylinder wear, and the DPF might not be in great shape neither, so I don't there's a lot to lose.
  4. #94
    Jul 2016
    Quote Originally Posted by hoddy View Post
    You can only work with that is in front of you, its worth a shot.
    I had a older tractor and it needed new rings, but of course they were as rare as unicorn ****, and i wasn't able to source them anywhere
    so i just used a heavier oil and it did the job.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
  5. #95
    Feb 2009
    Torquay
    Update:
    Van has been getting worse last 2 weeks. DPF light coming on all the time, and going into limp mode quite a bit. Have been able to clear fault codes while driving using the VCDS, which is good for taking off from lights, going uphill etc.
    But still bloody annoying.
    Rather than a new engine have decided to gut DPF and blank EGR.
    Just picked up the van from having this done. I also opted for a REMAP as well - why not - the engine needs replacing according to VW.
    WOW - the van is punchy lively and has more power than when it was new! Am stoked.
    Next step is to flush the oil out, along with the ferrous / silicon / crap from the corroded EGR.
    Will change to a thicker oil - liquimoly 10W40 - which might reduce some of the oil consumption (was 1litre per 1000).
    Will see how this existing motor goes - might still last some time.
  6. #96
    Mt Cotton
    How much approx. ?
  7. #97
    Jul 2016
    awesome, hope you get more km out of the engine.
    New oil will help, but interesting to see if does reduce the oil consumption.
    would running a engine flush agent in the existing oil, help before new oil?
  8. #98
    Feb 2009
    Torquay
    How much approx. ?
    It was $1300 quoted. But negotiated a bit less.
    Includes: Gutting of DPF, blanking EGR, software deleting, Remap/ tune.
    Given VW quoted over 17 K for new engine / DPF / sundries I reckon it's a no- brainer.
  9. #99
    Feb 2009
    Torquay
    Quote Originally Posted by Bryn23 View Post
    Local mechanic is going to sell me 20Litres oil, filter, and stuff to put in old oil before change. Apparently u let it idle for 10 mins with this stuff in, and then drain.
  10. #100
    Jul 2016
    Sounds like a great plan, that should help clear out the crap in the current oil.
    All up, its a risk worth taking, considering the cost of a new engine... i still can't get my head around $17k
