Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: vw t4 mushroom bolts???
    Mar 2009
    Sydney NSW
    Quote Originally Posted by DUB 20V View Post
    yeah i mght sell it not sure yet not even sure what to ask for it, know they are not a cheap item.
    Sent you a PM
    Now Adelaide!!!
    One of the nuts is a pain in the arse to get on the bolt.
    Its the one nearest the sliding door.
    The best way to fit it is to put the nut on a spanner and tape it on so it does not fall into the box section.
    Once tight you can pull the spanner and rip the tape.
    The spanner has to go in through a hole and at an angle.
    You dont have to make the nuts captive but if you remove the bolts then they will need to make them captive.
    Hope it helps Rob
