Ah I see, mine must’ve had a diy job on it then, bugger.
Isopropyl is what I had on hand and what we use to clean surfaces at work, haven’t tried any of those goo gone type products from Bunnings, they might be better suited for removing adhesive though. You’ll want something plastic to push/ scrape the adhesive and a few rags
The vinyl is fairly thin, it can be rolled up but I had a reasonably thick matte laminate on top and we have recently gotten in an even thicker laminate for floor stickers (social distancing stuff) so next try I’ll use that
It should be pretty durable
I've found that Oomph Remover works best for removing adhesive ... then follow up with isopropyl alcohol to clean up afterwards.
