Page 1 of 3 123 LastLast
Results 1 to 10 of 43
Thread: Volkswagen Washer Fluid
The_Hawk Volkswagen Washer Fluid 13-03-2011, 09:44 AM
Transporter Another way to save a bit... 13-03-2011, 10:10 AM
The_Hawk If you can point me towards... 13-03-2011, 10:11 AM
Umai Naa!! We don't carry the washer... 13-03-2011, 11:33 AM
The_Hawk It's flamable :D That in... 13-03-2011, 11:50 AM
Tornado T5 The flammability risk would... 14-03-2011, 09:14 AM
Tornado T5 At high concentration levels... 14-03-2011, 09:16 AM
magellan I bought a bottle of this... 08-04-2012, 11:58 AM
Diesel_vert Are you sure you got the... 08-04-2012, 02:53 PM
Tornado T5 Probably not worth the hassle... 10-04-2012, 02:04 AM
markwid Hahaha... I don't know... 10-04-2012, 03:50 PM
Transporter There is also Wurth Screen... 11-04-2012, 07:14 PM
ill0gitech Happily reviving an old... 16-07-2013, 05:02 PM
Sunny43.5 as I live in sunny Qld [well... 16-07-2013, 06:58 PM
MGV If you had 3 windshield... 16-07-2013, 08:39 PM
ill0gitech Volkswagen Washer Fluid 17-07-2013, 11:43 AM
JustCruisn Supercheap cleaner mix 1:50... 17-07-2013, 12:35 PM
Sunny43.5 Who gets out and smells the... 17-07-2013, 01:57 PM
VW Convert Kwityabitchn Howard, you... 08-05-2014, 04:02 PM
S.A I've just done this with the... 26-09-2013, 03:59 PM
The_Hawk Two and a half years on I'm... 26-09-2013, 08:59 PM
REVHE4D http://www.vwwatercooled.com.a... 08-05-2014, 12:01 PM
brad Just get something like... 08-05-2014, 12:58 PM
Kiels3927 When I bought my Multivan I... 08-05-2014, 04:34 PM
Sunny43.5 Often when you follow someone... 08-05-2014, 07:28 PM
    Dec 2006
    Kilsyth, VIC
    While most of it's rumor, there is some talk that if your washers lines ever clog up your warranty won't be covered unless your using the right fluids.
    The Volkswagen washer fluid isn't exactly cheap at $10/L, but then I don't know that there are many parts that are. Since we seem to tear through the stuff I thought I would look a little closer at it. The text on the bottle says:
    "Suitable for use all year round for the windscreen washing system. Offers the necessary protection against frost, stops the jets from freezing up, frees the windscreen from dirt and protects both paint and the wiper blades. Can be used in all models, must be used for fan-type jets."
    It's listed as being mixed at 1 part fluid to 4 parts water and since our reservoirs are 5L, that's a full bottle to fill it up from empty... or so it would seem.
    Last time around I thought I would measure how much I was putting in. The light had come on early in the week and it was continued to be used throughout the week then filled on the weekend. It seems that after putting in 1L of fluid I only got in another 2.5L of water for a total of 3.5L so that light comes on pretty damn early.
    I haven't tested running it till it doesn't work anymore to see how low it gets since I assume that most people would want to get rid of that light and re-fill the fluid.
    So onto some maths (and you thought you would never need it again). Assuming you started with the right concentration you now have 0.3L of washer fluid and 1.2L of water in the tank. Adding in the full bottle of washer fluid every time will see you end up with a concentration almost double the requirement of about 1 part fluid to 2.5 parts water. This means your good down to almost -16C!
    So to keep it 100% on what the documentation says you would need to add in 0.7L and top up with 2.8L water. Saving about 30% on fluid right there (although you then have to measure out the right amount each time. Something in my brain doesn't like this since you keep ending up with 300ml left in the bottom of a bottle...
    Plan B would be to get a 5L container and pre-mix it then just top up as needed (although I don't know how well it stores in this fashion).
    Plan C is to question the need for that concentration. I note that the various ratio's are all about temps below zero, the second to last one being -16C. I'm guessing a large part of the concentration is about not freezing. Being in SW Sydney I rarely see anything below 0C so freezing in the lines isn't a significant danger.
    Moving to a nice neat half bottle (0.5L) per re-fill keeps my OCD in check and means your running at about 66% the listed strength or about 1 part fluid to 6 parts water.
    Now maybe I just spend all together too much time thinking about these things. Maybe I just keep pouring a whole bottle in each time I fill up and not worry about it too much since I'm saving about the cost of a cup of coffee at work. That and it's only refilled once every 6 weeks or so anyway
    Adelaide hills, SA
    Another way to save a bit would be to buy the whole carton of the concentrate (buy in bulk and save).
    Dec 2006
    Kilsyth, VIC
    If you can point me towards an appropriate place where I could save a few $$ I'm always interested. (It's not like a don't have a 5 year supply of oil filters for the VR6 in the garage )
    Dec 2008
    Sydney/Canberra
    We don't carry the washer fluid at work, but Windex works pretty well.
    I wonder if it minimises algae build-up in the reservoir?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2006
    Kilsyth, VIC
    It's flamable That in itself is a big draw card for me
    Jun 2007
    Melb.
    The flammability risk would come from the high % of either Ethanol or Iso Propyl alcohol, most likely the later. This would aid in drying to give a streak-free result while importantly lowering the freezing point of the solution for European winters. Anyone have an msds for the product?
    I wouldn't bother with it here in Australia, then again I make my own. As mentioned, Windex will contain the same basic ingredients, just no where near the same level of some form of alcohol. iirc "in the old days" an alcoholic level below 10% didn't require a DG class 3 flammable liquid warning diamond.
    Jun 2007
    Melb.
    Quote Originally Posted by Umai Naa!! View Post
    At high concentration levels alcohol has sanitary/disinfection properties. Usually above 60% as evidenced by the instant hand sanitizers you see sold domestically and for say commercial kitchens applications. The VW product could also contain a dedicated biocide.
    Sep 2011
    Sorry to dig this old thread up, but where can I buy a bottle of that?? From my local dealer??
    MY12 147TSI Jetta DSG | CW | Sports Pack | Sunroof | Driver Electric Seat | RCD510 | Formula 1 Tint | MFSW Paddle Shifters
    May 2011
    Melbourne, Vic
    I bought a bottle of this stuff and foolishly mixed it as per the label for sunny conditions, ie 1 part fluid to 4 parts water. The guy at the parts counter did say use only a cap full. I should have listened to him as I now have a suds laden wash solution which spits rather than sprays on the window. I am now trying to get this crap out of the system so I can dilute it down with water.
    Quote Originally Posted by The_Hawk View Post
    MY 12 Golf GTI
    Jan 2009
    Quote Originally Posted by magellan View Post
    Are you sure you got the dosage right? Maybe it will just settle down on its own after a bit of time?
    Also, unless you were anticipating temperatures below 0°C, I think you should have bought a bottle of summer concentrate (G 052 184 A2) instead - better value as well.
