Post pics when your signwriting's done so we will recognise you. How did you come about the van? Was it a govt. sale?
Its a 8/2002 ex ambo, yet to collect it, will do in a week or so, has everything, dual air, turbo, cruize control, eleky windows, ABs etc, and upgraded suspention, it is 2wd, 2.5tdi.
so you tassie guys will see me out and about in tassie for sure, soon will be sign written.
Andy
Hey Brackie, Hows thing mate, i have been a little quiet latley, been in the UK and stuff, the van was for sale in Sydney at the Fowles Goverment Auction, they have synchros too, i decided to stay away from them, use too much fuel and later in life they get more exspensive to repair, i had some t3's which were synchros and was exspensive to keep up to scratch.
will post piccies fpr sure mate
Andy
I like the look of it....
Looks fabulous.
Was it a good deal from the auctions?
looks like you can drive a car into the back of it![]()
I own one of these but after conversion by Trakka, These vans are excellent value for money. How many ks? Does the auto work properly? I would recommend to change the trans fluid if it hasn't been done.
What are your plans for it?
Rob
Hi there volksfolks.We have just bought an ex ambulance V.W identical to yours. Ours was built 8/2002 as well and has done 55,000 ks. It was going okay until the battery indicator light on the dash remained on even after the engine was started and running. So the flat ribbed aternator belt was checked , it was okay, so then decided to take the alternator out ( very time consuming excercise) and had it checked out by an auto electrician. He replaced the regulator inside the alternator, retested it and said it was fine, pulling over 100 amps.Thought the problems were solved , reinstalled the alternator and flat belt and lo and behold the indicator light still won't go out, so don't know what to do now. Perhaps use it as the most expensive garden ornament, as it can't be driven. Any suggestions from anyone out there would be appreciated.
Take it to a dealer or VW specialist and have the software checked out. All it may need to start with is a soft reset of all the fault codes.....without VAG-COM or similar with these things.....even when you fix them....the computer will always say 'no'.
Our friend Cory bought a Syncro version, has had alot of problems with the wiring. The wiring was just cut, leaving quite a job to correct.
Maris
