Hey Seano,
That Featherlight FB, the Balsa substrate looks like a good product, so tempting i had to have a closer look at it.
At around 4kg a sqm, it is impressive, although I'm not sure how well a screw fitted drawers would hold in the long term into balsa wood.
It is technically a hardwood due to the grain structure, but i'd be a little worried able them putting on any rough roads, maybe a two pack expoy dipped screw would hold??
As for pricing, you are looking at these exc GST
2440x1220mm sheet
* 9mm $253.28
* 13mm $266.80
* 16mm $277.70
* 19mm $293.80
It is also made to order..
Nice product, but a little to $$ for me at the moment, as i'd also have to laminate it or veneer it as the veneer isn't A grade.
2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
In the camper unit I saw every component join was glued, taped and epoxied...
Like I said... not cheap. The old adage holds: light, cheap strong - pick only two.
