Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Vohringer/Altofina or similiar.
    Jul 2016
    Hey Seano,
    That Featherlight FB, the Balsa substrate looks like a good product, so tempting i had to have a closer look at it.
    At around 4kg a sqm, it is impressive, although I'm not sure how well a screw fitted drawers would hold in the long term into balsa wood.
    It is technically a hardwood due to the grain structure, but i'd be a little worried able them putting on any rough roads, maybe a two pack expoy dipped screw would hold??
    As for pricing, you are looking at these exc GST
    2440x1220mm sheet
    * 9mm $253.28
    * 13mm $266.80
    * 16mm $277.70
    * 19mm $293.80
    It is also made to order..
    Nice product, but a little to $$ for me at the moment, as i'd also have to laminate it or veneer it as the veneer isn't A grade.
    2017 VW T6 3200KG GVM LWB 132kW 7 Speed DSG (Campervan Conversion)
    Jun 2006
    with the dust and flies in western Victoria
    In the camper unit I saw every component join was glued, taped and epoxied...
    Like I said... not cheap. The old adage holds: light, cheap strong - pick only two.
