Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Very Noticeable Engine Vibration 2.5 TDI
    Mar 2008
    For some reason my 6.49pm reply has gone missing when I subsequently edited it to fix a typo I could not find instructions to contact the moderator to get it back? Scott
    Adelaide hills, SA
    Quote Originally Posted by Silver Caravelle View Post
    I’ve restored your deleted post. Could the reason why it went missing be that you’ve pressed “delete” instead save?
    Mar 2008
    Thanks Transporter, I was looking for the edit button and must have inadvertently deleted. Any way, thanks again. Scott.
    Update: After 6+ weeks of experiencing this engine vibration it disappeared yesterday just as mysteriously as it appeared. I'm happy, but perplexed.
    Adelaide hills, SA
    Quote Originally Posted by jjhobart View Post
    Could it be just a bad quality diesel?
    Sent from my SM-N950F using Tapatalk
    Well, the tank was checked, filter replaced and was almost at the end of the 3rd fill since the problem arose and I don't always buy from the same servo, so I'd be surprised. But I had put a couple of bottles of injector cleaner in the first 2 tank fills so maybe that had something to do with it.
    Aug 2016
    NSW
    I haven' use injector cleaner in any of my VWs.
    Anyone else used it?
    2018 Crafter Runner
    T5.1 6sp manual.
    Adelaide hills, SA
    I use it every time when I fill up. The right fuel additive (injector/fuel system cleaner) increases reliability, maintains good fuel economy. I also buy only BP Premium diesel.
    Aug 2016
    NSW
    I thought the whole thing about about premium diesel (which I use too) was that it contained the detergents already?
    On my T5, I am nearing 500K and have had no problems regarding the fuel system.
    2018 Crafter Runner
    T5.1 6sp manual.
    Adelaide hills, SA
    It’s good then. You probably drive under ideal conditions, always refuel at the good servos.
